No Hot Water
Aug 22, 2017
1,609
Hunter 26.5 West Palm Beach
I replaced a heat exchanger zinc that was completely gone.
Completely gone zinc may suggest that you now have corrosion/rust building up inside. I have seen passages rust up inside to the point where they were basically closed. Those zinc sticks can be important.
Feb 6, 1998
11,765
Maybe... But real old school. You might want to change it out.
View attachment 151879 your water heater brand may have a specific design. The one in this image is for a Torrid Marine. The white protrusion is an anode.
The white protrusion is the temperature probe, not an anode. It is the other half of T&P or Temperature & Pressure relief valve.
Thanks Mainesail.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I am thinking that over the winter my heating circuit sucked air via the pressure cap on the remote expansion tank. I recall that the overflow tank was not full, and there was air in the line from overflow tank to the pressure cap seat nipple. There's a pool of coolant in the sump pan under the engine, but that was there when things worked last Fall, and was explained as a spill during maintenance; I had a chance to clean it up. So, I'm going to clean that up, open the remote tank and fill it, fill the recovery tank and line to the proper level. Then I don't know; maybe run the engine 'til the thermostat opens before I fit the remote pressure cap? Fill as the engine's running and then cap it? Thoughts?
Here are Westerbeke docs on this. I have the system on the right, bottom of page 58, since my water heater is well above the engine.
jviss
Feb 5, 2004
7,090
The conclusion:
I pumped the excess coolant out of the under-engine fiberglass pan; about a quart. No signs of a leak, though. It was there when I bought the boat, I think a spill that was never cleaned. Apparently this can happen if you open the engine expansion tank cap once the higher remote tank is filled.
I opened the remote tank, and it was empty. The cap was wrong, too, a 13psi pressure cap that should be 7psi. I pumped in about 1 gal. to fill it, and also added to the overflow tank to the correct level.
Now I have hot water!
The bad news is there's a weeping leak from the remote tank. It's only a very small dribble. Of course, since it's Westerbeke, it's a $449 part! My plan is to bypass it with a piece of pipe and hose barbs temporarily so I can remove it to repair it - either JB Weld, or real aluminum welding.
http://discountmarinesource.com/sto...oNIgQny3_5zJXEcQkl0TFWuLqxxH7p6RoCXGQQAvD_BwE
