I think I got it set back up. ThnxThere are two ways to accomplish that in the New World Order. First, you can go to the forum you want to follow and click the Follow button, on top of the list to the right. Or, you can configure a Custom Forum to contain only the forums you want to see by hiding the ones you don't. That won't get you email alerts but figured it's worth mentioning.
There's also a feature that will send you a daily email with the five most popular topics from the prior day, but the link for that seems to be MIA. I'll follow that up.
Somebody probably answered this already but I haven't scroll to the end of the thread.Is there an equivalent to this link that can be used for bookmarking purposes?
https://forums.sailboatowners.com/whats-new/
The apps will be a few days yet.@isaksp00 I seem to be able to post from my Android phone, earlier try with a PC and both Chrome and Edge failed. How do we get the app - what is it called?
@DougM I suspect that will go away; you no doubt had a cookie or two set from the old board which caused that.Login using safari on an ipad is strange. Attempt to log in results in default to “Looks like you are already logged in” page. Then re-try finally results in a true log in.
Yesterday I attempted to post a reply with quote an it would not post at all
@FastOlson As Brian D said, it's "like." I'll change that label.Yesterday a thread refused to accept a reply. Today another one did so.
And, what is a "reaction score"?? (There was some sort of number associated with a member site name, and it is gone now...)
@uncledom We're working on that but it may be a while. The old version had a great plugin for that; the new one redirects you to the end of the thread you're marking read, which is ridiculous. So we may have to write something to replace it.Phil,
I used to filter for recents and if a post wasn't pertinent to my interests or I couldn't be helpful I could "mark post as read". I don't see a way to do that now in the PC version.
@DrJudyB Sorry about that, extended to 1 hour.The system cut me off after 15 minutes of editing. Can you check that setting please? I can’t organize my thoughts that fast!
Welcome to the best sailing forum on the globe.New member, I have a 30hp 4 cylinder universal engine in a Pacific Seacraft 37ft sailboat. Motor runs great at all speeds and loads however it is hard to start if starter fluid is not used in the start procedure. It has heaters on the injectors and I let it heat up the required 1-2 minutes before trying to start it. Any thoughts or ideas? Thanks David
You have a lingering issue with something from 1969?It seems we have the first multi-generational forum here.
Must be saving the date in the wrong format, but at least it doesn't read 12/31/1969.
Edit: this is fixed now.
Exactly what I was going to ask.Phil,
Is there a way to create a link to "New Posts" or "All forums All Discussions"? I can't seem to create one that works a second time??
My old link to "All Forums All Discussions" was:
John and Phil,New discovery. There is a time limit on how long you have to come back and edit your post. 15 minutes. I swear I did not leave the computer for 15 minutes.. Well maybe to make a little more coffee. But...
Thanks, Phil.@Stu Jackson, this should work for you:
*Just leave that number off the end.Code:https://forums.sailboatowners.com/whats-new/
I set the edit timer to indefinite. Brian, I'll PM you about All Forums All Discussions.Stu, I am the same. All Forums All Discussions was my home. I keep jumping between Recent Activity and What's New. I found Recent Activity does not update correctly, so now I am on What's New. It is the closest thing to All Forums All Discussions.
Phil reset the edit timer to 1 hr. That should help.
