New Forums: Questions, Suggestions, Comments
May 23, 2016
1,024
Catalina 22 #12502 BSC
Nice clean, fresh look, eze to navigate, no issues here (from laptop)....Well done!!!
Apr 8, 2010
2,118
Yesterday a thread refused to accept a reply. Today another one did so.
And, what is a "reaction score"?? (There was some sort of number associated with a member site name, and it is gone now...)
Feb 17, 2006
5,274
A reaction score was called Likes in the previous iteration of the software. It is still there, just not visible. Put your cursor over your avatar (or anyone's avatar) and you will see the reaction score. Don't click (you can if you want), just hover.
New discovery. There is a time limit on how long you have to come back and edit your post. 15 minutes. I swear I did not leave the computer for 15 minutes.. Well maybe to make a little more coffee. But...
Jun 11, 2011
1,243
Hunter 41 Lewes
Phil,
I used to filter for recents and if a post wasn't pertinent to my interests or I couldn't be helpful I could "mark post as read". I don't see a way to do that now in the PC version.
Uncledom. It is being worked on. I think it appeared then it vanished then reappeared now again gone. Something about the software link not functioning like it did in the new software version. I suspect it will come back. I liked the feature as well.
Likes: uncledom
There are two ways to accomplish that in the New World Order. First, you can go to the forum you want to follow and click the Follow button, on top of the list to the right. Or, you can configure a Custom Forum to contain only the forums you want to see by hiding the ones you don't. That won't get you email alerts but figured it's worth mentioning. :)
There's also a feature that will send you a daily email with the five most popular topics from the prior day, but the link for that seems to be MIA. I'll follow that up.
I think I got it set back up. Thnx
Jun 25, 2004
1,109
Hi,
I just wrote a loooong post which required a lot of editing after I posted it. The system cut me off after 15 minutes of editing. Can you check that setting please? I can’t organize my thoughts that fast!
Thank you for all you do for us
Regards,
Judy
Likes: Phil Herring
Phil Herring
Alien
Mar 25, 1997
4,923
- - Bainbridge Island
Is there an equivalent to this link that can be used for bookmarking purposes?
Somebody probably answered this already but I haven't scroll to the end of the thread. :)
Code:
https://forums.sailboatowners.com/whats-new/
Phil Herring
Alien
Mar 25, 1997
4,923
@isaksp00 I seem to be able to post from my Android phone, earlier try with a PC and both Chrome and Edge failed. How do we get the app - what is it called?
The apps will be a few days yet.
Login using safari on an ipad is strange. Attempt to log in results in default to “Looks like you are already logged in” page. Then re-try finally results in a true log in.
Yesterday I attempted to post a reply with quote an it would not post at all
@DougM I suspect that will go away; you no doubt had a cookie or two set from the old board which caused that.
@FastOlson As Brian D said, it's "like." I'll change that label.
Phil,
@uncledom We're working on that but it may be a while. The old version had a great plugin for that; the new one redirects you to the end of the thread you're marking read, which is ridiculous. So we may have to write something to replace it.
@DrJudyB Sorry about that, extended to 1 hour.
Likes: uncledom
Oct 24, 2010
2,405
Hunter 30 Everett, WA
New member, I have a 30hp 4 cylinder universal engine in a Pacific Seacraft 37ft sailboat. Motor runs great at all speeds and loads however it is hard to start if starter fluid is not used in the start procedure. It has heaters on the injectors and I let it heat up the required 1-2 minutes before trying to start it. Any thoughts or ideas? Thanks David
Welcome to the best sailing forum on the globe.
I suggest posting this under "Ask All Sailors" which is found under "Shared Forums".
Ken
Oct 24, 2010
2,405
I miss the go back link in each individual post. Example from a post in "Ask all sailors" the link takes you back to the "Ask all sailors" index.
Unless I missed something (highly likely).
Ken
Aug 1, 2011
3,972
It seems we have the first multi-generational forum here.
Must be saving the date in the wrong format, but at least it doesn't read 12/31/1969.
Edit: this is fixed now.
You have a lingering issue with something from 1969? :)
Likes: Phil Herring
Phil,
Is there a way to create a link to "New Posts" or "All forums All Discussions"? I can't seem to create one that works a second time??
My old link to "All Forums All Discussions" was:
Exactly what I was going to ask.
I'll keep reading this topic and see what happens.
Thanks to all for the upgrade and all of you who worked with Phil on this.
John and Phil,
This is just plain wrong. As in WRONG. Both Maine Sail and I are proponents of never-ending editing, and don't like forums without it. Sometimes things change, and sometimes edits in the future can make the original post better.
Please, please, please, make NO TIME LIMITS on editing.
Dr. Judy B's issue is important, too.
@Stu Jackson, this should work for you:
Code:
*Just leave that number off the end.
Thanks, Phil.
What number?
I used the whats-new c&p and now I understand.
Just not the side by side of the old legacy page, which many of us liked.
Thanks again.
Feb 17, 2006
5,274
Stu, I am the same. All Forums All Discussions was my home. I keep jumping between Recent Activity and What's New. I found Recent Activity does not update correctly, so now I am on What's New. It is the closest thing to All Forums All Discussions.
Phil reset the edit timer to 1 hr. That should help.
Phil Herring
Alien
Mar 25, 1997
4,923
I set the edit timer to indefinite. Brian, I'll PM you about All Forums All Discussions.
Feb 10, 2004
4,136
Hunter 40.5 Warwick, RI
Good job on the posting fix, Phil! So far I like the new format. One question- there used to be a symbol on a post that indicated that I have replied. Is there any way of implementing that? I see that any post I just look at or reply gets a "eyeball" symbol. If the eyeball was put just for posts that were replied, that would be fine.
BTW, the response on uploading a file seems to have gone supersonic!! Excellent!
