Looking for info - how to access stanchion base on 2005 H33
Oct 13, 2016
74
Hunter 33 Kingston
I noticed the flat stanchion base in which the stanchion sits is a bit wobbly and there are what looks like stress cracks around it. It's been there since I bought the boat and I suspect someone has tried to push the boat off while grabbing the stanchion. It's located on the starboard side, and just behind the plate where the shrowds attach at the deck. I've been looking inside and all I see is a type of semi-rigid material that fills the space between the hull and the plywood panel that runs under the deck. Can this material be pulled back without damaging it, and if so does this provide access to the stanchion from inside the boat?
I can't see any info in the owner's handbook about this.
Sep 20, 2006
2,955
Hunter 38 Georgian Bay, Ontario, Canada
You will need to drop the plywood hard board panel that is above the nav station and starboard settee. There are 6-8 screws covered with round almond coloured stickers in the panel. You can access the nuts from there. The base of the stantion has 2 threaded bolts going thru the deck.
