I have a swing keel off of a Cat 22 (1972, I think). A chunk broke off during retrieval from the sea floor (due to using the already enlarged hole as chain attach point - apparently a bad idea). The missing chunk now opens the hole all the way to the keel edge.
A welding shop thought they could repair it by welding/filling the entire gap, and then drilling a new hole, so I had it sandblasted first. Down to bare metal was the plan, but initial sand blasting revealed a "softer" core which is assumed to be lead (maybe lead filler in a steel or iron frame ?).
Sand blasting was stopped at this point since it was blasting craters in the lead.
The welder has suggested not welding anything but rather sandwiching 1/8" stainless plate around the opening and securing with screws through the plates and keel. Then inserting a bushing for the pin.
Any comments on any of this ?
-alternative repair method,
-will 1/8" stainless sandwich hold ?
-is there room to mount an extra 1/8" x 2 ?
-is it really lead ?
etc.
etc.
