I use a 2 ft pennant spliced to the clew eye. This is bent to the midpoint of the sheet with.......wait for it....
a sheet bend.
a sheet bend.
Hi Walt, welcome to SBO forum. Do you have a picture of your rigging on the headsail? I'm unfamiliar with your description.I use a 2 ft pennant spliced to the clew eye. This is bent to the midpoint of the sheet with.......wait for it....
a sheet bend.
Brave man.I use a 2 ft pennant spliced to the clew eye. This is bent to the midpoint of the sheet with.......wait for it....
a sheet bend.
I did the same thing but went with a double fisherman, which you pass the bitter end through the clue on each side of the sail. Basically works like a stopper knot of each side of the clue. Clean, simple and strong. Only down side is, I'll likely have to cut it out.I've new rigging on order and will use a single sheet, attached with a cow hitch, for a couple of years. Then, I will cut out the four inches of weakened line at the center and use bowlines end to end to extend useful life for several more years. I'm surprised there's no votes for a buntline hitch here, which I'm considering moving forward.
Just a word of warning, I lost a bowline in 18 knots Sunday afternoon. First time in 45 years on sailboats.
I was trimming the sheet by hand, using my weight to help. Foolish, rookie mistake. Landed on my backside in the cockpit, unhurt, but it is very sobering to think that solo and with tiller pilot engaged, miles from shore in water too cold to survive an overnight, I would probably be dead had I gone over the side.
Whatever knot or shackle we choose, let's use the winch handles God gave us to trim our sails safely.
DrewI would probably be dead had I gone over the side.
