Catalina 27 1985 with M18 Universal engine starts and sounds normal.. When I shift into forward or reverse, engine stalls out. I've changed fuel filter once and Racor filter, twice, removed fuel lines from both injectors and I can blow air through the lines, so not clogged. turned engine on and bled air out of fuel line at the fuel filter; racor filter- bled out water and added Diesel 911 to Racor filter and additional Diesel 911 to fuel tank. It still stalls out when I put engine into gear. WHY? Is there a governor on this engine and does it interact with the Transmission and engine at the same time? Any ideas will be greatly appreciated.
Buddy Shea
Buddy Shea
