Okay so im the proud new owner of a cat 22. The deck/cockpit/rubrail could be in better shape. I’d like to get this boat looking as best I can with my skill level and resources, which admittedly isn’t much.
The PO owner freely admitted he used rustoleum from a spray can to paint the deck (wut) so my current plan it to sand it all down as much as necessary to get a good surface.
My questions.
1. Spiderweb cracks in the paint/fiberglass. Can I sand it down and hope it’s surface level? Or do I need to dremel it out and epoxy it? What kind of epoxy is best?
2. The cock pit floor is uneven. Is laying down a complete sheet of new fiberglass the way or can I use a thickened epoxy and sand it even by look.
3. At what point do you sand so much you need a fairing compound?
4. Is a new layer of gelcoat necessary? Or can I go straight to primer?
5. If I sand through the nonskid, im guessing I need to tape off the nonskid areas and use a nonskid paint. But if I sand it smooth how do I know where to tape it off?? Can I just paint the whole deck nonskid? Or would that look horrible?
6. Is a two part paint absolutely necessary or could I get 90% of the results with a good one part?
I know it’s a lot and there’s lots of threads on this so I appreciate whoever actually reads this. This boat is my life now and I’d like to give her the facelift she deserves! Thank you
My questions.
