Some hints on setting up the amount of draft in a mainsail:
1. Sailmakers generally target/design a mainsail so that the designed amount of draft is typically at optimum for sailing in 12-15 kts. of wind.
A. At much less than 12-15kts. such a sail will need to be flattened to lessen the risk of a leeside separation stall - an invisible separation of airflow from the leeside due to the airflow not having enough 'energy' to stay 'attached' to the leeside. Low energy / low speed airflow will generally separate (stall) if the airflow is forced to 'turn corners'. Most 'cruising' design sails will have a 'rounded' shape to the luff section that produces a 'forgiving' shape for the inattentive (cruising) helmsman; the rounded shape luff leading edge (from the edge of the luff to about 5-10% back) being 'rounded' is where the separation stall will begin to occur.
A sail (for non-planing/displacement sailing) that is cut/designed for racing has a greatly reduced 'roundness' at the luff area, is less subject to separation stalls, has a very small range of angle of attack ... the helmsman needs to be constantly 'on' to keep the racing sail within its designed 'un-forgiving' angle of attack.
B. 12-15kts of wind usually implies a wave height of approx. 2 ft. (for coastal or inshore/lake sailing; larger waves for sailing 'offshore'). Unless specified otherwise by the purchaser, the 'plain vanilla' sail will be designed with normal amount of sail draft for this 2ft. of 'chop'.
There is a relational 'balance' between sailing in waves OR in 'flat' water.
Waves require that the sail develop POWER to 'punch through' waves .... hence the design amount of draft inbuilt to the sail (12-15kts w/2ft. waves).
Rx: The balance of these two sailing conditions ... sailing in (2 ft.) waves OR sailing in 'flat' water requires differing amounts of draft: Full draft for POWER for 'punching' through or into waves; OR, flattened (less) draft for SPEED sailing in 'flat' water.
Flat sails = HIGH gear (speed); Well drafted sail = LOW gear (power) ......
• How to set the correct amount of draft for EACH day's sailing conditions:
1. Go onto a beat and adjust sails for 'perfect' tale tell flow (all tales perfectly streaming straight back, but IGNORE slight so-called 'backwinding' !!!!!).
2. ADJUST the amount of OUTHAUL tension while watching the speedo !!!!!!!! The correct amount of mainsail draft will occur when the speedo is at its 'maximum'. Adjust outhaul tension to arrive at maximum boat speed. Readjust shape and trim to keep the tell tales properly flowing, etc. and repeat with outhaul adjustment, etc.
2a. For light winds and little to NO waves, start with a fully tensioned outhaul and FLATTENED mainsail. The flattened shape will help prevent 'separation stalls' (watch your tell tales for separation stalls on the leeside).
2a Alternate. On a boat with a 'bendy rig' - a fractional rig whose (tapered) mast can be severely bent by extreme backstay tension, begin by applying maximum backstay tension (to reduce draft/flattening) and slowly release that backstay tension while watching the speedo for max. speed .... plus while or in addition to adjusting the outhaul.
Backwinding: is a condition when the 'recirculating air flow' AROUND each sail is mathematically canceling each other IN the 'slot', (the combined and sum total of opposing) recirculating airflow speeds IN the slot is approaching zero and the sails are operating at near MAXIMUM aerodynamic efficiency (you may even see that some of the midcord windward side tell tales are (correctly) pointing 'forward' in 'perfect' circulation flow conditions !!!!!) .... OR the shape of the luff front edge of the main is 'too rounded', .... or the leech of the jib is operating too close to the mainsail, etc.
Rx: 'slightly' release jibsheet tension to 'open' the slot distance; 'slightly' increase the mainsail outhaul tension (flatten the main); release some tension in the mainsail halyard (relocates the point at which the max. draft occurs towards aft - but not so much as you induce noticeable 'weather helm') ...... BUT BUT- while watching the speedometer; all adjustment for so-called backwinding is to gain MAXIMUM boat speed (VMG).
Its entirely OK to carry a 'happy bubble' of slight/occasional 'backwinding' .... if the boat is sailing at MAXIMUM boatspeed when 'pointing'. If the backwinding is 'detractive', consider using slightly 'smaller' jib or a jib with more concave ('hollow') shape to its leech, or open the slot an inch or so - whatever is FASTER.
For sailing is SUPER LIGHT winds and flat water: consider to install a 'row of steering tell tales' on the jib. A horizontal row of 4-5 tell tales on each side of the jib at 'eyeball height' of the helmsman. When the aft-most steering tell tale on the leeside begins to droop down - separation stall !!!!, so 'head up' a degree or two and/or 'reshape'/flatten the sails .... all done while watching the speedo AND the leeside tell tales !!!!!!!!
For sailing in super-light winds, most boats will sail well/fast if the sails are set-up/shaped the exact same as when sailing in 'above' 15 kts. of wind. ...... flattened!!!!!!!! Watch the SPEEDO when 'shaping' the sails, always aim/adjust for MAXIMUM boat speed and watch the tales for 'separation stalls' on the leeside.
Summary - The outhaul is what controls the amount of draft, the tension in the mainsail halyard determines fore/aft where the point of maximum draft occurs in the main (weather helm).
Use lots of sail draft for when sailing in WAVES; FLAT sails for speed sailing in FLAT water, ..... once you have all your tell tales flying correctly.
Flat sails = HIGH gear; Well drafted sails = LOW gear ......
Adjust in/out on the outhaul according to the SPEEDO. Doing so will automatically adjust the correct amount of draft for the day's wind/wave conditions.
Other.
Setting slot distance - General rule: jib clew comes IN towards the boats centerline in super light winds (but typically not so that the jib tack to clew angle or angle of attack to the centerline is LESS than 10°), jib clew goes OUT away from the boats centerline in 'blammo' conditions. Adjust in accordance to maximum BOAT SPEED obtained.
hope this helps.
