Cabin top winch relocation
Nov 8, 2010
11,386
So, let's try this again: WHY is it a PITA to not be able to go 360 when you could just as well do back-and-forth 180s?
Because not being able to stand over a winch and swing it 360 actually IS a PITA?? ;^)
Likes: chrisings
mortyd
Dec 11, 2004
952
Catalina 30 easy living
the real issue might even be who makes and installs dodgers without room to crank the winch around.
Beneteau 323 Annapolis MD
[QUOTE="...the real issue might even be who makes and installs dodgers without room to crank the winch around.[/QUOTE]
I made my own dodger and the mounting I could muster just could not allow 360 rotation unless a shorter handle is used. No problem to do 360 that way. B323
mortyd
Dec 11, 2004
952
ron, we have catalina 30's, and i've seen many with dodgers well made enough to allow complete freedom to use the cabin top winch.
Nov 8, 2010
11,386
The weight of a sail can very greatly, depending on the weight of the dacron cloth or its construction. Our laminate race main weighs about one half what our Dacron does.
Also, a track system has MUCH less resistance than slugs.
Full battens much more resistance than partial.
So no easy blanket comparison.
615
Catalina 385 Marquette. Mi
U
Wait till your boat is 30 years old. does yours have simple nylon slides?
Ummmm.......not the headsail. My POINT was maybe, just maybe an 8" winch handle might not hit his ill designed dodger. Is this cat fight over yet?? :). Just trying to help...but I guess not.
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
U
This post from OP is about the Mainsail.
Jack, good one! :) Oh, you youngsters! :yikes::confused::clap::clap::clap:
morty, we have what I consider a VERY GOOD, well made dodger. It is low, so I can see over it. It has nothing to do with the dodger, it has EVERYTHING to do with where the winches were placed by the builder.
Like this:
http://c34.org/bbs/index.php/topic,7161.msg48397.html#msg48397
See my earlier posts on this engaging topic! :deadhorse:
mortyd
Dec 11, 2004
952
stu, like almost always we basically agree, but i guess catalina did the winch placement before even considering a dodger, so those who want a dodger are limited by catalina's design. in eleven years, until now, i didn't know this was an issue since my winch/dodger combination works just fine, and if it ain't broke.......
Nov 8, 2010
11,386
stu, like almost always we basically agree, but i guess catalina did the winch placement WITHOUT considering a dodger, so those who want a dodger are limited by catalina's design. in eleven years, until now, i didn't know this was an issue since my winch/dodger combination works just fine, and if it ain't broke.......
Fixed that for you. Unless a dodger is a factory option, this is normally the case.
Ted
Jan 26, 2005
1,280
I hear this all the time.
Could you please explain why you think you need to do this? Is it not a two speed ratcheting winch?
Even on my jib sheets, unless we're racing, I don't bother to go 360.
Stu, the reason it's a PITA by not rotating the winch handle the full 360 degrees is because you are going from high gear to low gear as you reverse directions with the handle. (Assuming this is a two speed winch). I can't imagine using this method to bring in a fully loaded genoa, racing or not. It's a difficult and slow method unless there are really light winds which I don't believe you get too often in San Francisco. Your method would work better with a one speed winch. You could also use a ratcheting winch handle in conjunction with a two speed winch. You'll be limited to one gear ratio until you switched the direction of the ratchet on the winch handle.
mortyd
Dec 11, 2004
952
ted, i have no idea how your c&c is rigged, but here we are talking about a catalina 30 whose cabin top winches control only the main and jib halyards: nothing to do about jib sheets.
Ted
Jan 26, 2005
1,280
Mortyd, I was responding to Stu's comment, hence the quote. This thread is a bit intertwined with a few related topics. My comments are also relevant to the original topic.
495
Catalina 30 St. Croix
I also have a ratchet handle that I bought in 1080. It has the same palls as a winch
Flick the lever and you can ratchet in either direction.
Jul 6, 2013
223
Catalina 30TR, Atomic 4 2480 Milwaukee
I use a Milwaukee right-angle drill.
It's a little awkward for trimming the sheets, but great for the halyards and rolling in the furler.
