I use a hockey stick, it's a light composite material, bends yet stiff, easy to swing,  after years of poking and slashing, the blade finally broke... and I epoxied a hook on the end.
				 www.txfowlers.com
					www.txfowlers.com
In addition to the two boat hooks I have, I'd really like to have a grapple - not too big, but one that I can use to snag lines and other things in the water as the need or want arises. I have only seen ones that are bigger than what I'd want to keep on board. Any ideas?
Large, dulled, weighted, three pronged, snatch hook with 200lb test line.In addition to the two boat hooks I have, I'd really like to have a grapple - not too big, but one that I can use to snag lines and other things in the water as the need or want arises. I have only seen ones that are bigger than what I'd want to keep on board. Any ideas?
Watch Deadliest Catch for the proper way of throwing these things. Most of them use an overhand "no swing" technique that requires very little room.Thanks, that looks good. One would have to be careful tossing one of those from a sailboat, with all the lines, rigging, bimini and dodger framework, etc.!
Thanks!Watch Deadliest Catch for the proper way of throwing these things. Most of them use an overhand "no swing" technique that requires very little room.
I made my own. Took 1/4" diameter 316 stainless rod, one longer, one shorter, with about a 1 1/2" diameter curve on both ends. Folded the two rods using the longer rod to make an eye for a line to attach and then welded them together. Makes for a nice easy to throw 4 pronged grapple that isn't too heavy and yet quite strong. Doesn't damage other boats if you throw it to them. Because of the 4 hooks, grabs things quite nicely. Overall length is probably about 6 or 7 inches. Width across the grapples probably about 4 inches. I've never measured it. I'd take a picture but it's on my boat.In addition to the two boat hooks I have, I'd really like to have a grapple - not too big, but one that I can use to snag lines and other things in the water as the need or want arises. I have only seen ones that are bigger than what I'd want to keep on board. Any ideas?
Nice! Please make one for me!I made my own. Took 1/4" diameter 316 stainless rod, one longer, one shorter, with about a 1 1/2" diameter curve on both ends. Folded the two rods using the longer rod to make an eye for a line to attach and then welded them together. Makes for a nice easy to throw 4 pronged grapple that isn't too heavy and yet quite strong. Doesn't damage other boats if you throw it to them. Because of the 4 hooks, grabs things quite nicely. Overall length is probably about 6 or 7 inches. Width across the grapples probably about 4 inches. I've never measured it. I'd take a picture but it's on my boat.
dj
No! I mean, I don't expect you to, but it would be awesome if you did. I'd pay for it!Is this a joke?
dj
Awesome, Will. What size would you recommend for general sailboat use?https://www.amazon.com/Grappling-Gr...ocphy=1021897&hvtargid=pla-305509097642&psc=1
S size: 12 x 10 x 6cm|4.7''x3.9''x2.4'' Load bearing: 40kg|88Lb
·M size: 13 x 12 x 8cm|5.1''x4.7''x3.2'' Load bearing: 60kg|132Lb
·L size: 19 x 16 x 9cm|7.5''x6.3''x3.5'' Load bearing: 125kg|276lb
-Will
I have no idea. I've never thought to use something like that for sailing. Probably the smallest one that would hold my weight when scaling castle walls.Awesome, Will. What size would you recommend for general sailboat use?
