Thanks. I got the cap off, it's destroyed. Now I am puzzled.Destroy and replace the caps. They are a consumable and should be replaced anyway.
..., replace the caps with "Bearing Buddies" to keep the new bearings in good shape.
I did search and read and watch several article and videos. Clean fitting and new gun. No amount of pulling & twisting budged it. Ended up pulling the fitting out of the Bearing Buddy. Grease Gun still attached.If you listen and watch the example I got from a simple Google search and YouTube playback you will understand how to fix it and why it happened. My former mode of solution was to get a bigger hammer and then ask a farmer how to fix it after I broke it.Google Search
www.google.com
