Battery Issue possibly?
May 24, 2004
7,228
CC 30 South Florida
I did not mean to mislead when I said it would take 4.5 to 5 hours to recharge batteries. I should have added that I seldom discharge batteries very deep and that this is the average time it takes me to recharge mine. The whole point I was trying to make is that it takes hours to recharge batteries and that the process cannot be rushed nor interrupted.
Feb 6, 1998
11,772
And this is a very, very good point! Many folks often don't understand how long it actually takes to fully recharge a battery...
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
It really doesn't matter that the batteries were new last year; they could have been no good when you got them! I've had brand new Interstate batteries that were garbage, heavily sulfated. Fortunately the dealer took them back. Also, you can ruin good, new batteries in less than one season by improper charging and use.
That charger won't properly charge those batteries, as Maine Sail points out, and isn't appropriately left "on" unattended.
I guess the batteries are no good now. You need new batteries and an appropriate charger.
Jun 1, 2019
32
Oday 30 Saugatuck
Thank you all that responded. So it sounds like most signs point to a new charger, done and done. Previous owner used a cheap car battery trickler. I purchased a new Guest charge pro 5/5 from west marine. Looks like an easy set up. That and some cleaning up of the connections, I may be in the clear. Alternator is still in question but let me try the new charger first.
Jun 1, 2019
32
Oday 30 Saugatuck
I did dig up my battery info:
2 Interstate Batteries, 24M-XHD Cranking, 800 cold cranking amps, 135 reserved capacity at 25amps. $126 a piece.
Are they no good after a year since I brought them down to 0% and tried to charge with an inferior charger?
jviss
Feb 5, 2004
7,090
You can test them, try them out. With that new charger you bought it could take a long, long time to fully charge them. Then discharge them with a known load to 50% state of charge and see how long that takes.
Check the water. Don't add water before charging unless the plates are exposed to air, and then only enough to cover the plates. After charging water to the proper level. Only distilled water.
Check state of charge by, when you think they are charged, taking them off the charger, waiting an hour, and then placing a small load on them briefly to dissipate any surface charge. Then measure the no-load, i.e., open circuit voltage to at least two decimal places.
This page has a state of charge table:
https://www.trojanbattery.com/pdf/datasheets/SCS200_Trojan_Data_Sheets.pdf
100% is 12.73V. Yours might be slightly different, but not by much.
We don't know the AH rating of your batteries, as this is seldom stated for cranking batteries. Assume 75AH, and for the test put a 2A load on each, or 4A if they are wired in parallel, and see how long it takes to get down to 12.10V (50% SoC). if it's much less than 20 hours, they are not good.
Jun 1, 2019
32
Oday 30 Saugatuck
Hey gang, just a quick update. I replaced the battery charger and everything works great. One year old batteries still good. Nice to use a charger from the “modern era.” Lights up and everything. Thanks to all those that responded.
