YOT doth float. Most everything went without a hitch other than a slight gas leak at the fuel pump, a stuck fuel check valve at the tank and the electrical fire when the ammeter shorted to ground and burned off the insulation. The repairs were quickly attended and I am happy to report the old Atomic 4 barked to life. The Hayn Hi-Mod fitting I used for the backstay is a cinch to use. As you may remember I had the split backstay with adjuster but opted for a single fixed stay. Ordering extra length on the backstay a quick cut and assembly were an onsite rigging walk in the park. With the mast up the final measurements were placed with the order for a 140 Genny and an Asymetric Spinnaker from none other than the good folks at SBO.
