Use it to attach a block anywhere where you need a little more freedom of movement than a steel shackle provides.Just out of curiosity, where would you want to use a soft shackle?
I'm a fan of bowlines honestly... but that's a conversation for another thread.OK. Thanks for the quick reply. I had heard about putting them at the jib sheet ends. I currently use a single jib sheet with a cow hitch in the middle. Soft shackles better?
I like the cow hitch too... makes the jib clew slide over the stays'l stay easier than a bowline would.OK. Thanks for the quick reply. I had heard about putting them at the jib sheet ends. I currently use a single jib sheet with a cow hitch in the middle. Soft shackles better?
Thanks Mark. I was just thinking of adding an "emergency" anchor on my stern rail but didn't want to leave the chain and rode attached because I have no easy way to get it into the lazarette and don't want to put more holes in the boat. A simple soft shackle would be a very quick way to attach the rode and deploy the anchor in an emergency.Dyneema is more abrasion resistant than high carbon steel. One of its common usages is in chafe protectors for other rope types - also in cut and abrasion resistant gloves. Our shackles show no wear after a year of dragging through sand and rubble. If we regularly anchored in sharp rocks or coral (who would?), then I might have more concern. Even just cutting this stuff is tough to do - I keep a special ceramic knife for this purpose (cuts it like butter). A regular steel knife needs to be sawed back and forth and the dyneema often frays as it cuts.
But the thing to remember is that a soft shackle costs $1 and 15min of time. I keep several around and can just replace one at any sign of weakening, or just on a routine basis.
Mark
To clarify, we use a soft shackle to attach our bridle (snubber) to the chain - not to attach the chain to the anchor.Thanks Mark. I was just thinking of adding an "emergency" anchor on my stern rail but didn't want to leave the chain and rode attached because I have no easy way to get it into the lazarette and don't want to put more holes in the boat. A simple soft shackle would be a very quick way to attach the rode and deploy the anchor in an emergency.
