Our exhaust fan is noisy but with the engine noise and the fact that everyone is in the cockpit when the fan runs, the only noise we do hear is the air blowing out of the exhaust vent.
Often when we are motoring, Sue is down below either reading, cooking or sleeping which is why we installed the sound insulaton.
			1.  Here's where I get a little lost.  The 120mm case fan you refer to is a squirrel cage fan?
2.  The 4" elbow is used to duct air from "that"?  "That" refers to the previously mentioned case fan ?  So this is now a positive air supply back to the alt ?
3.  I like it.  Where does it get its air supply from .............  the same below water supply as your 1" gap I presume?
1.  There would be two fans.  The red hose has the squirrel cage fan with hot exhaust air.  That fan is currently mounted at the back edge of the port cockpit locker where Catalina installed them, but I can look into moving it to nearer the engine.
2.  The blue rectangle is a new fan that I plan to add which will be a 120mm computer case fan. It will be mounted to the outside of the sound foam over a 4" ø hole through the foam. A 4"ø duct elbow will be mounted to the inside to direct the air flow to the alternator. It will pull cool air from the below deck space between the liner and the hull which is cooled by the cold PNW seawater. You are correct, the 120mm case fan provides positive cool air flow directly to the back side of the alternator case where its air intake vents are located.
3.  The air for the 120mm and the 1" gap under the sound-foam both come from the cool space between the hull and liner so it should be very cool. The gap is passive, and the case fan is active. That is a good thing because it is problematic to have a forced intake and exhaust for the same space in a controlled loop because it is easy to get an unbalanced air flow, but the passive intake will balance any short fall. In no circumstance should the case fan be able to create positive presser which would be bad because it could force fumes into the cabin. That should not happen because the squirrel cage has greater flow than the case fan and add to that the volume of air that the diesel sucks in, I should not have any problems with fumes in the cabin.
			All I can add is to make sure your supply blower
into the engine compartment supplies less ft³/min. than the exhaust fan is capable of removing
from the engine compartment.  Due to turbulation  of air within the engine compartment, the supply fan could probably use a manual speed controller such as this cheap piece of crap :
It's a just a DC/DC transformer which you may want to spend a little more money on to ensure it lasts for more than the first week
 . It looks like it "might" go from 0 - 12V but no guarantees.
Please let us know how it works out as you've got me thinking about adding a supply fan.  Pretty easy set up with my engine compartment.
I do not think I will have any problems with too much positive air flow as indicated above.  If I do need to throttle the fan I use PWM.  I already have three of them on Papillon.
On the Hydronic heat I have two of them.  One controls the fan speed the main cabin heat fan coils.  The other controls the speed on the head fan coil.  The PWM controllers I use have only a 3A relay and the two fans for the main cabin are 120mm @ 3.75A and 80mm @ 2.8A.  The head has a seperate 80mm @ 2.8A fan.  All of these fans are PWM computer server fans with the standard 4-pin wiring.  I hooked up the +&-12v directly to the power supply and only the PWM control goes through the controller and it works great.  I can turn them up to 100% and they will blow the dust off the walls but howl like a banshee.  I do that when I first come on the boat when it is cold to get the cabin to warm quickly.  Once it is up to temperature, I slow the fans down to about 10 to 15 percent and they are almost silent.  That way then run on less than an amp total for all three of them.
The third one I have is for the fridge.  It originally had a 0.49A two wire case fan that was the loudest 12v thing on board.  I now have a 0.5A PWM and I run it at about 40% which cuts down the Ah used by the fridge and makes the cooling cycle work much better because it used to operate in the "Super-cooled" region where the freon would not fully evaporate until an inch or two after the capillary tube.  In the AB manual, it states that if the air temperature to the condenser is below 60º you should block off 1/2 of the face to reduce the air flow.  I did it by slowing the fan and using less energy in the process.
Better boating through Engineering!
I do not use any of the rheostat speed controllers like the one
