always look forward to your interesting posts 25. Been really fun following your project. I can't wait to see your work on the 37. Now for some discussion on sails. I've managed to build several from Sailrite kits including a cruising chute (asym), storm sails, 130 Jib, etc. I found a 150% headsail too large for most conditions and was having to sail with it partially rolled up more often than not, a situation that ruins the performance of the sail and limits pointing ability. I find a 130% is perfect for most conditions and then in the spring or fall when the winds are a little stronger I switch to my 110%. I don't know the conditions up on lake Ontario so you may be happy with a 150%. You can cut down a jib to a smaller size by removing material from the luff in a very specific way, Sailrite has instructions on how to do this if you are so inclined. Also a cruising chute is a bear to pull in. You usually pull it in when the winds pick up so it is really tough, of course mine is a lot larger than yours will be. Consider a dousing sock. I had my cruising chute explode on me one day, it was very spectacular :>) .
