I need to add cabin heat to my boat. Best option because of space limitations and a desire for hot water would be an Espar water circulating system but is will be as much as a new set of sails and all new standing rigging even if I do the whole installation myself. Unless something unexpected happens, I can't swing that and still the the cruising that requires the heater.
I just went up to measure and look at the cabin and there are two options for either a diesel or solid fuel heater which would be less than half the cost:
I can remove the cabin table and shelf unit and install a stanchion at the aft end of the existing table and build a new, shorter table that mounts on a piece S.S. lifeline tubing between the mast support and the stanchion. The stanchion and table would make moving around in the boat underway a lot easier and I sail with few enough people now that I could live with a smaller table.
This would give me enough room for a floor mounted heater next to the mast support. Two problems: I would have to give up being able to convert the port berth to a double but I seldom carry the fill in cushion anyway. I can live with that. The big problem is that the only possible smoke head location is right next to the mast on the side where I raise the main and reef. I would have to cap it when sailing and would be dropping the halyard coil directly on top of it. Having the heater at floor level would be nice though because it is my feet that feel the cold the most.
There is also room to cut into the hanging locker on the other side and build a tile lined alcove that would keep the heater well away from the berth. I can get 10 1/2" depth. I don't use those drawers much anyway. The deck space on this side is not nearly as precious as there is little line handling there except when raising or lowering the roller jib. The most attractive thing about this option is being able to use a Sigmar with an air intake from deck to avoid back drafting problems when it's gusty or the companionway has to be opened. The second duct could run through the locker and I could put "Y" on it to draw air from inside the boat when I want to dry things out and it isn't too windy. The main drawback of this arrangement is that the heater is mid height in the cabin which means a cold floor.
WHICH would you do?
WHICH would you do?
