How to attach more rode?
2,288
C30 Event Horizon Port Aransas
I just picked up 200' of nylon 3 strand. I put a splice in one end and whipped the crap out of it with thick polyester thread, just to make sure it stays. I was thinking about splicing the other end for attaching to another rope to increase scope but thought I would ask how it should be done first.
I am not going through a windless or any restrictive area. I plan on putting a shackle on the end of the chain to attach this rope to. I see a lot of ropes spliced to the chain. But I don't think I need to worry about that.
Is any one attaching ropes together to anchor? If so how?
Ross
Jun 15, 2004
14,693
If they are the same size then short spilce them. If they are not, then eye splice them with thimbles.
Edit to add: two whippings a few inches apart are better than one.
Sumner
Jan 31, 2009
5,254
If they are the same size then short splice them. If they are not, then eye splice them with thimbles.
http://purplesagetradingpost.com/sumner/MacgregorTrips-3-Powell09/09-10-5-Powell-09.html
I ran into this problem at Lake Powell where one 200 foot line wouldn't reach a suitable rock onshore to tie two. I just had to tie a knot in them there as I didn't have time or the right parts (thimbles) to do better. They held as I'm here, but I wanted to do something better as knots really decrease the strength of a line.
Ross I was going to do what you suggest, but and maybe this is what your are suggesting, I am going to splice thimbles on the ends and then put a shackle through each thimble with one link from a chain in the middle between them.
So it would be end of the line with a thimble, then a shackle that goes through the thimble and one side of the single or two chain links, then the second shackle goes from the chain link to the other thimble.
I wonder if this would work better than one shackle linking the two thimbles directly together. Anyone done either of these? Is this what you are suggesting Ross?
Thanks,
Sum
Our Trips to Lake Powell, UT - Kootenay Lake, Canada - Priest Lake, ID
Our Mac Pages
Mac Links
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Not necessarily the strongest but maybe the easiest
if you have an eye splice in each rode you can pass one line through the eye of the other then back through its' own eye. It is good practice to eye splice triple strand also instead of just whipping the end to keep it from fraying I like to use a backsplice, very professional looking and very easy once you do it a few times. If you are using braided line you can make the eye splices using my "Magic Splicing Tool" that I have advertised right here on this site many times. I am not making a lot of money on the "Magic Splicing Tool" because they are free by making them yourself.
Sumner
Jan 31, 2009
5,254
Thanks I'll look for the "tool".
Would these lines then always be together or would you make the splice on the spot or what? I want to keep the rodes separate unless I need to put them together to get the length. At that point I might be trying to anchor/tie to shore at a difficult time and/or place, like in the picture, and need to do it quickly.
Thanks,
Sum
Ross
Jun 15, 2004
14,693
If you wish to separate the lines then a shackle is the way to go. otherwise Interlock the two thimbles and eye spilce them each. A back splice is excellant but a sewn on whipping is almost a durable.
Jan 27, 2008
3,092
A braided eye splice takes a little time.
If you are in a real rush you can always go with a couple of bowlines but lose a bit of strength because of the knot. An eye splice retains about 90% of the line strength. I like Ross' suggestion of a shackle, quick, easy, strong.
Here is another picture of the "Magic_Splicing_Tool." Somewhere in the archives I posted directions for use. Search on magic splicing tool to find them. This tool is fantastic and it is virtually free. I've used the fancy expensive tools, in comparison the inventors should be in the cell next to Bernie Madoff. They stink. The magic splicing tool was invented based on a tool I bought that worked great but broke after a few uses. I looked at it and said I can make the same thing out of a coat hanger for free and it will never break. I still have the original tool and it is going strong. For smaller line you just need a piece of smaller diameter stiff wire to do the same thing.
Triple strand is simple to splice but braided takes some practice, so if you are in a rush this is not the way to go but if you splice your lines in advance with eye splices then they are ready for use as dock lines. Putting in a thimble as Ross suggests still requires a splice so use the tool.
24
Ericson E-38 Bay City, MI
Ashley Bend
Long term I would definitely suggest a short splice. But whenever I have had to do this sort of thing - either with shore lines or anchor lines - I have always preferred to trust the Ashley Bend knot. It's very secure and easy to tie, though like most knots it will reduce the line strength a bit.
Beneteau 323 Annapolis MD
Put the thimbles on end of each of the lines. Instead of your thimble-shackle-chain link-to shackle-to thimble, get maybe a foot of heavy chain to loop through both thimbles, then shackle the two ends of the chain together with an also-large shackle.
2,288
I would like to be able to undo the ropes if I wanted to. I take it a short splice is like the eye splice but for joining two ropes. This that I just bought is 3 strand and the other stuff I have is braided.
I guess I will eyesplice them with thimbles.
I used stainless shackles when I first bought my chain, I left it in the water for two weeks when I prepared for a hurricane. when I pulled up the chain it was half rusted. I need another chain. I only had 30', this time I will buy 60' or so.
Sumner
Jan 31, 2009
5,254
Thanks for the idea Ron, but I don't know what I would be gaining? We all know the saying "a chain is only as strong as its weakest link" . What your suggesting would be strong at the union of the two rodes, but my weakest link would be one of the links by the anchor section or probably the line itself. I also can't get any bigger chain than I'm using through the eye of the thimble. The chain link with a shackle on each side would be easy to store and attach. Also the shackles would be orienated with the rounded end on the thimble eye like they are where the chain meets the rope on an anchor rode and the squared off end would be on the link like it is on the anchor rode. Maybe I'm missing something :confused:.
..............I guess I will eyesplice them with thimbles. .............
http://www.animatedknots.com/splice/index.php?LogoImage=LogoGrog.jpg&Website=www.animatedknots.com
jibes138 -- Thanks for the picture. I was able to find it last night after a bunch of searching. I'll try it out and if it works good I'll send you a check for what it cost me :).
c ya,
Sum
Our Mac Pages
Mac Links
2,288
c ya,
Sum
Our Mac Pages
Mac Links
Is that special rope that splices it's self? That is a very cool animation. I think coloring the strands would help, I think my splice has a misbraid in it but it is a foot long and whipped so I guess it's ok.
That animation reminds me of a film I saw when I was a kid 20 years ago on HBO where film eats a guy in a studio. It was done stop motion likie that.
Sorry, Hermit, I overlooked the part where Sumner hijacked your thread and there were two different problems being discussed.
Jan 27, 2008
3,092
Hermitt Let me get this straight
Are iyou saying your problem is how to connect a double braid rode to a triple strand nylon rode?
You can't do a short splice in this case. Look at the picture of an eye splice. If you want to connect two straight lengths of triple strand you can basically splice them together just like an eye splice but without the loop. First splice one into the other starting some length away from the end, then unlay the strands of the second line and splice those into the first. You end up with a straight, very strong line but with a big bulge in the middle where the line is about twice as fat as the rest. After each splice put the splice on the ground and roll it with your foot to smooth it out and make it round.
So getting back to triple strand to braided. I say go with an eye splice on each, then pass the straight end of the braided through the eye of the triple strand, pass the straight braided end through the eye in the braided rode and pull it all the way through to cinch it up on the braided line. No shackles, no chain, just rope and pretty strong. It will come apart fairly easily but you might need your rigging knife to pry it apart. When I made my Jordan Series Drogue I bought lengths of 5/8 braided line I got as remnants at Defender and I connected them this way. Since there was already one joint in the design like this the extra joints don't weaken the rode any more than the first one. Each joint further away from the boat has less stress on it. I made a bunch of eye splices in braided line with my magic splicing tool so I got a lot of practice. The magic splicing tool was invented when I paid 11.95 for the best tool ever, but it was a brazed assembly and broke after a couple uses. The coat hangar has no joint to break and is good ductile strong material. The little hooks on the end are to hook into the sheeth to pass it through the core. You hook it in place then use whipping twine to hold it or just some painters tape will work with care. Learn how to make braided eye splices it is a great thing to learn for your boating toolkit. Paying someone to do this for you is a waste of money, just follow the directions step by step and you will have a eye splice as good as any.
2,288
Yep, sorry if there was any confusion on that,
Sum
Confusion for what? I read the whole post again and I can't find how you or anyone highjacked the post. Ron, please explain that, or are you joking? Sorry if I am missing an obvious joke.:confused:
Jun 1, 2004
8,323
Carrick Bend... not shackles and splices.
Hermit...... The knot you can use to add a similarly sized section of line to your exisiting rode or tow line is called a "carrick bend"
http://www.animatedknots.com/carrick/index.php
Using this knot will allow you to employ your newly purchased line for other purposes, like towing or extending a mooring line. If you're jonesing to tie in an eye splice.. just put it on one end. Leave the other end plain (and whipped, of course).
Jan 10, 2009
590
PDQ 32 Deale, MD
Neither splices nor knots fail in practice on boats this size.
Who is kidding whom? Chafe. Loose shackles. Old splices with loose thimbles are a menace - very sharp.
Either the carrick bend or figure-8 (see post for modified version - http://sail-delmarva.blogspot.com/search?q=splice+knot) are reasonable choices and are 85-90% strength knots.
Have you EVER seen a mountain climber splice a rope, though they are willing to fly through the air on one? Better yet, show me a documented case of a modern UIAA approved climbing rope failure that was not over a sharp edge. Ropes are quite dependable until damaged. Knots are quite dependable and the rope is un-modified.
My last set of dock lines lasted 15 years, due to careful chafe protection. I just chafed a new line 60% of the way through in 2 weeks because somehow it got looped over a rusty nail. I hate people who put nails in pilings - sooner of later they do damage to rope or gelcoat, and there are better ways. Stupid. Every gel-coat ding I have ever suffered was from a stupid piling add-on that someone though was useful, but did not think-through. The nail is gone now!
Ross
Jun 15, 2004
14,693
Re: Neither splices nor knots fail in practice on boats this size.
Braid and three strand joined is harnessing an ox and a horse to the same plow. They will both work but they work better alone than together. The carrick bend is strong and reliable but bulky.
Edited because of fat stubby fingers.
