I too am a lock it in reverse guy. I suspect if your dead wood is big enough locking it vertically would be better but who knows. This test really surprised me...Great test!
What do you think about a 2 blade in a cut out, behind a full keel? My Bristol seems to sail 1/10th knot faster with the 2 blade locked vertically. I like the quiet of a non-spinning prop and shaft while sailing.
That I have no idea on. I would probably rely on the PHRF handicap rules where a 3/sec mile handicap is applied to a fixed three blade prop. If I recall it is a 6 sec/mile spread between a feathering prop and a fixed three blade.I wonder how 30 pounds drag translates into speed loss. I guess the only why to know would be to tow a boat at a given speed and see how much force it took. Then reduce the towing force by 30 pounds and see how much you had to reduce speed to make it happen. That way the drag would subtract from the net pulling power of the sails.
For me one minute per mile is a non issue.That I have no idea on. I would probably rely on the PHRF handicap rules where a 3/sec mile handicap is applied to a fixed three blade prop. If I recall it is a 6 sec/mile spread between a feathering prop and a fixed three blade.
For most cruisers six seconds a mile is a non issue..
Dog... Please re-read it, specifically item #7 in the original post.How much drag does a freewheeling prop get from the transmission? If the freewheeling prop spins more freely than the freewheeling prop attached to a transmission, then the test isn't going to be accurate...
With my boat and PSS seal my prop will spin at under 1 knot. I compared the jig to my own boat using the digital scale. I pulled my prop with the digital scale and Gorilla tape from the outer tip of the blade and then compressed the friction bearings on the jig, with pipe clamps, until I matched the pressure it required to spin my prop while on the boat. Every boat has different friction depending upon transmission, cutlass condition and stuffing box. This is measured against my own boat as the baseline.
Again this is NOT for exact numbers, though I have tried to replicate my boat as closely as I can including the props depth below the surface of the water, I did this because I know someone from which ever side does not win will probably enter into a debate about water density at a certain depth.
I did as best I could. You'd be surprised how close it was.you need to duplicate the shaft and shaft angle.
I'm sure you did and am not surprised at all. What I meant is that you would need a different test set up to be sure of the results for my boat with it's very steep shaft angle and fairly long length of exposed shaft.I did as best I could. You'd be surprised how close it was.
It's not quite as bad as it looks. A basic factor in prop selection is the fact that the water isn't flowing over the prop at the same speed the boat is moving through the water. The drag of the hull moves some of the previously motionless water forwards. This is a big component of the drag. The closer to the hull, the more the water is moved. From the reference point of the boat, this is a reduction in the speed of the flow, usually called Va, Speed of Advance, or Wake Fraction.At 5 knots, surprisingly, the fixed prop drag equals half the hull drag.
