Tom,Love to see MaineSails resulting tests before I release some extensive tests that I have found. But I trust MaineSail to still run the tests in a methodical way and show the results that he gets.
But here it is - Freewheeling has much less drag ! (but its usually not good for many transmissions and bearings with all the extra wera and tear)
(cut to the chase - go to pages 37 and 40 for figures 6 and 8 here -> http://strathprints.strath.ac.uk/5670/1/strathprints005670.pdf )
or another one but I think you'll need to purchse study for full result
http://www.sciencedirect.com/scienc...serid=10&md5=503e86665aa47e781a6ce7ea5b02a4bf
Those are both the same study. You really don't need to buy the second one as it basically says the same thing as the accepted manuscript does. This was one of the studies we discussed last time, as well as the MIT study (I have copies of both). Some here made arguments that seemed to have some merit, specifically tank wall interference, and in the case of the MIT paper, the vortexes & turbulence caused by the internal piping.
So with all that disagreement, even after two Universities published their findings, I am doing this very simple, non-tank but more real world test, to finally get a more precise answer.
I plan to video this one so there is no confusion..
