Diesel fuel can for boating
Nov 23, 2015
20
Hunter 33 Coconut Grove
I've used a shaker siphon, works great but my hands always end up smelling like diesel. The Surecan works great but a 5 gal can weighs a lot to be holding high enough to empty. I have a 2.5 gal one I use for the outboard and never had issues.
I do keep a white engine drip pad with my siphon. I have a bag with a ziplock with the siphon, a couple white pads, a funnel and small cup for collecting the last remaining..I keep Biobor Jr. in the bag too.
Likes: Bob S
Mar 6, 2008
1,508
I wear gloves to keep my hands clean.
Sep 28, 2025
98
Catalina C 30 MK1 1983 Stockton Lake Missouri
My transferred pump cost 25 bucks and It does a gallon per minute of diesel fuel. The only problem is I need a 12 volt DC source so I have a riding lawnmower battery that I use for other things also if a source isn’t close.
Do you use this filter when pumping from a dock pump also? How much fuel do you take on when filling your tanks?
dj
I don't generally fill the diesel tank at a fuel dock and this thread is about filling from jerry cans. I have used this filter funnel at the fuel dock and it requires a bit more care than just sticking the nozzle in the fill pipe. One should always be monitoring tank level during fuelling; failure to do so can result in a spill from the tank vent. This is not the same operation as "gassing up the car".
EDIT: the Racor funnel is not really much different than a Baja filter...something that has been used to keep diesel tanks clean for decades.
dLj
Mar 23, 2017
5,129
Yes I realize this thread is about using Jerry cans. But I was curious if you used that both ways. I rarely fill from Jerry cans as when I take on fuel, it is usually in the 75 to 100 gallon range. That's a lot of Jerry cans... I only use Jerry cans as emergency back-up or where I need fuel but there is no fuel dock. I was simply curious how that set-up worked pumping from a dock hose. Thanks for the off-topic answer.
dj
Jun 21, 2004
3,152
Beneteau 343 Slidell, LA
Do you monitor your fuel gauge when filling or wait for the pump to shut off or overflow?
I listen for the fuel to start accumulating in the onboard filler hose. A fuel dock attendant taught me that trick many years ago. I guess that he had seen enough spills in his tenure to devise a fool proof method for filling a tank. Also keep several paper towels handy, just in the event that I have an overfill.
dj
Hi DJ. As I said, I have used the Racor funnel at the fuel dock but it takes a lot of care - the funnel doesn't pass the fuel as fast as the flow from the nozzle (due to the filtering), so there is a lot of start and stop. Unlike you, I have never had to buy more than 30-35 gallons at a time because I have never owned a boat with a tank bigger than that. I keep the boat on a mooring in front of my house and the nearest fuel dock is a half hour away, so it's usually easier to top up from Jerry cans. When I am going further afield, I use Jerry cans to refuel because normally there are no fuel docks where I cruise. Scepter Jerry cans with the vent built into the spout are my my preferred product. Another off-topic answer for you.
dLj
Mar 23, 2017
5,129
Now that is something I'm definitely going to look for! Never heard of them. Thank you much!!!
dj
Likes: Jim Legere
