Honda BF5A 5 Hp 4 Stroke.
Trying to get working after sitting 4 years. Its said to have ran good 4 years ago. 4 years ago the PO changed the main oil and the gear oil... then it was never touched until now. Sat in a garage for 4 or 5 years. Now hoping there's not too much to repair/replace after that long nap she took.
Also can not figure out the year. I've looked everywhere cant get a confirmed year so I can get the manual.
I'm assuming will need....
New Impeller. (would I also need to replace any gaskets here..?)
Clean the carb.
replace fuel filter?
New Plug
Oil
Gear Oil
Fuel filter
Anything else I'm missing....?
It was not seized at all. I gave it a couple pulls and the recoil gear cog jumped up and over top of the starter flywheel. This was dumb to try to start it without lubricating? Could I have done damage? I did though just get the recoil and all back and that is working again.
What should I have done in this situation as first action?.. taken off spark plug and just pour some mystery oil in there than manually twist the flywheel clockwise gently to disperse it?) .
I did find the stamped Engine serial # bade1210150
Says model is BF5A. But can not find the product # and cant figure out the year to get the manual and order parts.(Says product # should be stamped on swivel case.. but It's not, looked everywhere, 3 times, lol)
Searching for year/model using these numbers.,... I'm seeing anywhere from a 1991 to a 1997? Can anyone tell me what year this is and where to find the manual for it online?
There is a cap missing down lower on the shaft (see pic) ? Is that bad after sitting for 4 years like that in a garage?
Thanks guys... Really appreciate your help! I want to learn... and everyone's been really haling me along on these forums.
Clean the carb.
New Plug
Oil
Gear Oil
Fuel filter
