Possibly wrong boat, but dreaming.
dLj
Mar 23, 2017
4,823
Get that bolt cleaned, take more photos - then we can see what we are looking at. The nut looks good - it is inconsistent with the appearance of the bolt.
dj
Oct 26, 2025
26
Ericson 26 mark IV Bayview
dj
Looks to me like it's a gonner, but I'm not sure why it's just that one and the other ones are perfectly shiny and new on the outside. Due to the design of the bilge, it could be that this one was exposed to much more water over its life. Well, how much is this going to cost me?
dLj
Mar 23, 2017
4,823
Why isn't the nut corroded, only the top section of that stud? If it were sitting in water and that was causing it - then that nut should also show corrosion - get to all cleaned up and free of corrosion product - then it may be easier to tell what's going on. That whole thing needs to be shinny clean. Can you get a wire brush in there?
dj
Oct 26, 2025
26
dj
That was about an hours worth of scraping and scrubbing with a brush. You can't really see it on the picture but I can feel huge divots in the bolt profile with jagged pieces of metal (what's left of the threads,) next to them. I think that is what's left of the stud. I can keep trying to go at it, but the giant gouges or pits keep getting deeper.
dLj
Mar 23, 2017
4,823
Yes I can see the divots. But that part of the bolt doesn't matter. It's what is under that nut and the rest of the bolt going down into the keel. If the corrosion stops at the top of the bolt and the rest of the bolt is not corroded - it doesn't matter about the section sticking above the nut.
Once you get it cleaned up well, then you are going to have to take that nut off and see what's under it. You'll probably have to soak it in something like PB blaster or another product to get that nut moving. Once you do that you will discover what is needed.
dj
Nov 8, 2007
1,610
After some research on Lake Pend Orielle by Ponderay, ID. I think your Ericsson 26 is a great boat to sail there! It's big enough to have several good anchorages, a few mooring fields, and a number of marinas to visit. Looks like a fine place to acquire sailing experience!
Docking at a marina or club will give you a good chance to talk with other sailors and build your local knowledge of the lake, including how to play the winds off the surrounding mountains.
As you say, Flathead Lake, 3+ hours to the east, is another opportunity. When you are comfortable in Lake Pend Orielle, I highly recommend the longer, 7 hour trip to Anacortes, WA, to sail in the San Juan Islands nearby. This is one of the best cruising grounds in the world. While the islands are protected from the North Pacific, they will allow you to deal with tides, and a wide diversity of anchorages, all of it in truly beautiful waters with exciting sea life. (We have especially enjoyed orcas, seals, and fishing eagles there.) Again, your boat is ideal for both of these cruising grounds.
