Oddly, when I wrote to HumsiENK about an updated app, I got a response from WattCycle…
Is there any connection between these 2 companies that you are aware of?
Separately, here is the latest note I have received from HumsiENK…
The issue you’re seeing with batteries not staying perfectly in sync when paralleled is a common phenomenon across lithium batteries. Our team is already working on optimizing the app to improve monitoring and ease of use.
The 14.6 v charge was only to try and get both batteries ( charged independently) to 100% SOC before wiring them in parallel. This instruction came from Humsienk. They also said limit the amps to 5. Charge for a couple of hours.
It seemed to help.
When I was out this week, this was the state of the batteries after charging…
Both batteries at the same voltage and a % difference in SOC
View attachment 234430 View attachment 234431
After sailing, and before I put them back on the charger…identical.
View attachment 234433 View attachment 234432
