Terminal connectors
Feb 16, 2021
439
Hunter Legend 35.5 Bellingham
Would you use these on your boat?
Amazon purchase. I don’t want to create headaches down the road…
Mar 26, 2011
3,739
Corsair F-24 MK I Deale, MD
After crimping, pull the wire out. It should be very difficult and damamge the ring in the process. (See column 2.) You may need to adjust the crimpers to fit.
Should be tin plated copper.
Mar 6, 2008
1,356
The bottom 3rd icon from right is a ship. I guess it can be used in marine environment. Is there a statement on the box that it is made out of stainless steel?
Feb 16, 2021
439
It is non magnetic. The product descriptions claims it is tinned red copper, but a light scrape of the surface with a sharp blade doesn’t expose copper…
Jan 7, 2011
5,666
Oday 322 East Chicago, IN
I have used something similar. No issues as long as you crimp it well.
But I am in fresh water (Lake Michigan) and not exposed to a salty environment.
YMMV.
Likes: Timm R Oday25
Somethings on a boat you can scrimp on a bit, others you're inviting problems. Off brand electrical products fall in the latter category.
Feb 16, 2021
439
Here’s an image of one of these connectors after I cut it and submerged in salt water for 36 days. Do marine grade connectors typically hold up better? Or is this on par?
dLj
Mar 23, 2017
4,430
Was this a standardized test or just something you tried? If it was a standardized test - what was the test method? If it's just something you tried - no one can answer your question.
dj
You might want to experiment with some marine labeled connectors. I think pretty much all of them corrode when immersed in salt water.
Likes: BigEasy
Clearly the tin plating is eroding. The exposed metal does not look like copper. Cut the fitting so you can see a cross section to verify that is is copper.
Jun 21, 2004
2,927
Beneteau 343 Slidell, LA
Usually use Anchor connectors (West Marine) or generic connectors from . Gregsmarinewiresupply.com. Heat shrink insulator & spray the connector with CRC anti-corrosive spray or coat with Lanocote. Don’t know if it makes any diffence, but can’t hurt.
What are you folks using as fasteners ?
I prefer 3m or Molex connectors. Waytek Wire sells them. Lately I've been using and pleased with BSP connectors from Defender, decent price and good connectors. In a pinch I'll use Ancor. Ancor uses a very short section of insulation, I prefer longer sections insulation.
Mar 2, 2019
606
Oday 25 Milwaukee
I was asking about the fasteners , not the connectors . I've tried a variety of different types metals of .
Corrosions from different metals seems to accelerate the process . I've tried stainless ,zinc brass screws
