Terminal connectors
Feb 16, 2021
464
Hunter Legend 35.5 Bellingham
Would you use these on your boat?
Amazon purchase. I don’t want to create headaches down the road…
Mar 6, 2008
1,389
The bottom 3rd icon from right is a ship. I guess it can be used in marine environment. Is there a statement on the box that it is made out of stainless steel?
Feb 16, 2021
464
It is non magnetic. The product descriptions claims it is tinned red copper, but a light scrape of the surface with a sharp blade doesn’t expose copper…
Jan 7, 2011
5,786
Oday 322 East Chicago, IN
I have used something similar. No issues as long as you crimp it well.
But I am in fresh water (Lake Michigan) and not exposed to a salty environment.
YMMV.
Likes: Timm R Oday25
Somethings on a boat you can scrimp on a bit, others you're inviting problems. Off brand electrical products fall in the latter category.
Feb 16, 2021
464
Here’s an image of one of these connectors after I cut it and submerged in salt water for 36 days. Do marine grade connectors typically hold up better? Or is this on par?
dLj
Mar 23, 2017
4,598
Was this a standardized test or just something you tried? If it was a standardized test - what was the test method? If it's just something you tried - no one can answer your question.
dj
You might want to experiment with some marine labeled connectors. I think pretty much all of them corrode when immersed in salt water.
Likes: BigEasy
Clearly the tin plating is eroding. The exposed metal does not look like copper. Cut the fitting so you can see a cross section to verify that is is copper.
Jun 21, 2004
2,997
Beneteau 343 Slidell, LA
Usually use Anchor connectors (West Marine) or generic connectors from . Gregsmarinewiresupply.com. Heat shrink insulator & spray the connector with CRC anti-corrosive spray or coat with Lanocote. Don’t know if it makes any diffence, but can’t hurt.
What are you folks using as fasteners ?
I prefer 3m or Molex connectors. Waytek Wire sells them. Lately I've been using and pleased with BSP connectors from Defender, decent price and good connectors. In a pinch I'll use Ancor. Ancor uses a very short section of insulation, I prefer longer sections insulation.
Mar 2, 2019
618
Oday 25 Milwaukee
I was asking about the fasteners , not the connectors . I've tried a variety of different types metals of .
Corrosions from different metals seems to accelerate the process . I've tried stainless ,zinc brass screws
