Ranger 12 - rescue
Jun 26, 2025
17
Ranger 12 Maple Valley
Hello all, wanted to say hi. new to the forums. I am in the process of bringing back to life an old Ranger R-12 that has been left... I see a lot of work ahead. but will hopefully have her ready to sail again by next summer. Looking forward to the wisdom from those on this forum who have been down this road before me.
Sails, mast all seem in good condition as they had been stored in a garage. The scuppered gunwales are not salvageable. they are too far gone and rotting way. Once I get it back to my garage in the next day or two will start to go over the boat and start to make a long list. at least once small hole in the fiberglass above the waterline along with a lot of cleanup.
Thanks for posting. I'll be following your story with interest. Please keep us informed and post pics!
Likes: rhsc912
Jun 26, 2025
17
Well she has made it back to my garage. I’m waiting for a small dolly to arrive so I can move her around easier. she’s going to need a lot of love.
1. Fiberglass repair
2. Gunwale replacement
3. Center board repair
4. Tiller handle non existent
5. Oars non existent
6. Rotten top of the transom
7. No traveller
mast and boom seem ok at a glance. I’m sure that’s is more I’ll find.
Looks like a fun project, and you’ll have a nice little boat at the end of it. I look forward to reading as you progress.
So that is faux planking? No judgement. It’s like the Montgomery’s. The fiberglass looking planks should be a lot easier to clean up than replacing boards.
I’m not really giving instruction but I’d be inclined to document the gunwale and inwale details and then start fresh with new wood. Maybe one side at a time. That may involve steaming. Small boats have more severe curves than larger vessels. You may want to brace the boat athwartship to maintain the lines while the trim is off the boat.
It’s just good fun and involves some time in the thinking chair with a beverage!
Likes: rhsc912
The scariest part I need to figure out… how much rot is in here
I can't see all the areas of concern in the photos but the knee on the stern(?) is toast. Again you need to stabilize that shape with twarts while you replace it. Doing the bevels and angles could be challenging. Time to spend in the thinking chair. Go with replacement not repair.
Likes: rhsc912
Jun 26, 2025
17
Port side knee is trashed, starboard side is not as trashed. Maybe clean enough for a template… the wood sandwiched in the transom is rotted for sure. Just don’t know how far down.
the port side inwale is not horrible. Maybe clean enough to use as a template. There will be plenty of chair and beverage moments.
She been laying upside down for some time
In a mulch bed. the source of all the soaking moisture
Nothing good happens fast
Jan 5, 2017
2,464
I once did a rebuild of an International 14 that was in about the same shape. It was a lot of fun with my12 y/o son. We later did a camping trip in the Gulf Islands with it.
Likes: rhsc912
Jun 26, 2025
17
Found these tucked away in the sail bag. Seems like the owner was going to make some repairs in 1998 and didn’t get around to is. Original packaging from Ranger Boat too.
Co.
Likes: Michael Davis
Jun 26, 2025
17
Last photos for the night. I promise :)
and yes it very much feels like Christmas in June!
Boat #42
Jun 26, 2025
17
So any thoughts on order of operations? As of right now, I have a chair and beer in hand and looking over the problem areas. ;)
My initial thoughts are the following order.
  • Transom Replacement (First) I am not sure how far down the rot goes, I am assuming it is all rotted.
  • Knees Replacement (Second)
  • Gunwales Replacement (Third)
  • Fiberglass hull repair (Last)
Tackling the Transom...
  • Remove Hardware: rudder gudgeons.
  • Cut Away Inner Skin:
  • Remove Rotten Core: Chisel or scrape out the rotten plywood/fiberglass core.
  • Prepare New Core:
    • Use marine-grade plywood or Coosa board as a replacement.
    • Cut it to size (multiple layers if necessary).
    • Seal plywood with epoxy resin (West System or TotalBoat)
  • Install New Core:
  • Re-glass Inner Skin:
Seems reasonable. Fiberglass last definitely makes sense to repair any tool marks from along the way. The others would just depend on if any part is in the way of another. Maybe wait on putting the last coat of finish on the gunwales until you’re sure you don’t need to flip the boat again and risk scraping them.
First template the transom. Put a cleat across near transom in case the transom while excavated can’t maintain the boat shape.
I was thinking last pm that we’re acquiring a fair amount of corks - for better or worse. I was wondering why cork wouldn’t make a good substitute for end grain balsa in core repairs. The round corks would fit together without a lot of trimming. I have no idea how the cork and resin would interact but I’d be interested in other opinions. Cork is light, resists water migration and is flexible. Seems like pretty good properties.
Likes: rhsc912
Jun 26, 2025
17
The inner side of the transom is much thinner. I figured if I leave enough of exterior in place… 6” or so. That gives me enough room to excavate, leaving the thicker exterior transom in place. Also while I realize the 1/4 knee is in rough shape on one side it’s keeping shape. Seems like lot with a strap or two should help keep the shape of the stern
