I'm not sure what you are pointing out with the above.
When one wants to hand crank a diesel engine, you use the decompression levers so the pistons, fly wheel, that entire structure, can be spun up fast enough so that when you drop the decompression lever the engine can start. While you are spinning up, you are likely going to go through the compression stroke several times while getting everything up to speed. Obviously, with the decompression lever on, you don't get compression - it's purpose.
Now, once you've got everything spinning at a high enough RPM, you flip the decompression lever. When that happens, you don't really know where in the cycle that piston is at, so all this stored energy has to be able to carry that RPM through an entire cycle in order to have a complete compression cycle. Now, if you think you can flip that decompression lever at exactly the bottom of the compression stroke, or if you think you can get everything moving at the required RPM from the bottom of that stroke to the top while hand cranking, well, you are a better than I am.
But maybe there is something I'm not understanding. I'm all ears.
dj
You kind of changed the focus from "the engine has to be at 200rpm to start" to something about hand cranking. I was pointing out that the 200rpm has to be a rate of change, and not a velocity. Sort of like when you tap your knee reflex spot, your leg moves at a higher speed for a short distance than you could ever run.
A compression stroke is not a compression stroke without compression. So that part is neither here nor there when the decompression levers are open.
There isn't anyone here who can hand crank an engine at 200rpm regardless of decompression levers open. That is 3.3 revolutions per second. Put a winch handle in an unloaded winch and try to turn it 3 times each second. 60-80rpm there will have you huffing.
Rate of change is velocity over time - a vector quantity, while speed is the magnitude of this rate - a scalar quantity. So one could achieve a 200rpm rate of change when starting the engine by quickly enough moving the handle just the 100mm (4") distance of the piston's stroke if that piston was at the bottom of its compression stroke.
If one piston isn't at the bottom of its compression stroke, one of the other pistons will be - assuming it isn't a single cylinder engine. So even if you needed to move the crank handle more than 4", it will likely be less than 12".
So to start a diesel, the engine must achieve a 200rpm rate of change for a very short distance. The engine itself does not have to achieve a speed of 200rpm. The high torque of starters make this rate of change easily achievable in such a short distance without having to get the engine up to 200rpm speed. A weak battery does not allow the starter to turn hard enough to get this rate of change.
Going back to hand starting, if there is enough momentum at the slow cranking speed achieved by us mortals, then when the decompression levers are closed, the instantaneous rate of change of a piston stroke during a compression stroke will be higher than the engine's speed when the levers were closed.
Mark
