Interior wood slats for C30?
Sep 24, 2018
4,648
Catalina 30 MKIII Chicago
Does anyone know if there's a source for premade wooden slats that are on the interior walls of the C30 MKIII? I think some areas might be too far gone for sanding. Would prefer to buy premade than to sand, shape, lacquer, etc
Catalina 320 Dana Point
The original supplier in California was a place in Rancho Dominguez that closed about a decade ago. I'd inquired about new floorboards and the owner advised me they supplied them as "trim to fit" because the boats varied. He said if I brought the old ones in he'd make exact fit. When I returned a few weeks later he had passed the night before. I don't think they made any 30's in Florida, but you might check with the factory for their current supplier.
BTW I don't think those are slats but Ash plywood.
Maybe you could find tongue and groove thin flooring or paneling to make your repairs.
Finding an exact pre-made match for the interior of a 30 year old boat seems to be looking for a unicorn. :what:
Perhaps finding a boat that was destroyed in a storm and being parted for salvage might be a possibilty. :)
Playing with mature boats requires a sense of wonder, a spark of ingenuity, and a lot of persistence.:biggrin:
Sep 24, 2018
4,648
I had a feeling these might not be available or worth jumping through multiple hoops just to pay through the nose. Thanks for confirming the material @Calif. Ted and @Stu Jackson. How successful do you guys think sanding will be? I know I wont be able to remove all of the stains but it's in the aft bunk so it's not very visible. What should it be re-coated with?
Ward H
Nov 7, 2011
3,842
C30's were made in Florida starting with the 1990 model year until end of production. The PO claimed to have sourced them from Catalina in Florida and installed them on my 93 MkII.
You might want to give Catalina Yachts a call and check. I did when I needed a new mast head casting. They had two collecting dust. I bought one at what I thought was a very reasonable price. Maybe you'll find the same with the plywood slats.
And yes, they are plywood. I've had the one over the hanging locker off several times.
dmax
Jul 29, 2018
1,345
Telstar 28 Buzzards Bay
In my 1989 C30 they were definitely ash strips and not plywood, so they must've changed shortly after.
Likes: Ward H
Ward H
Nov 7, 2011
3,842
It's possible they were thin strips laminated onto plywood. I didn't look at it that closely but it did come off in one piece.
Likes: dmax
Sep 24, 2018
4,648
Nah this is a Catalina. They're too cheap to use extra material. This is glued directly to the fiberglass. So far it's falling off in one piece! I'll pull it off the next time I'm there
Try a small spot way far aft, got nothing to lose...
Good point!
Likes: Ward H
Sep 1, 2014
39
Catalina 30 MKII Gulfport, FL
Thanks for all the info.
Mine are looking pretty bad and decayed. But hey it's an '89 also. I live in FL, not too far from factory, and have had good luck finding forgotten wood in their buildings. Will give that a try first.
But frankly, the boat and I are getting too old to.keep it up. It is amazing how much still works or can be repaired on old boats.
A neighbor passed recently, and his family is trying to sell his 50 year old, one owner J24, with a new $10K trailer. Hoping to get $10K from someone who will take a project on.
Nov 25, 2013
51
O'Day 26 325 Lake Erie, Sandusky, OH
I had an O'Day 26, which came with a burlap material on the walls. I liked the Catalina look, so I went on a quest to find the material you seek - I was unsuccessful. Not to be deterred, I bought some rough sawn ash lumber - 2" thick ×,10" wide x 9-10' long. I saw them into 3/8" strips and planed them to 1/4" - routed the edges, and sanded all smooth. I rubbed tung oil on them - about 7 coats. Tung oil makes repairs super easy if they ever get buggered up. In my experience - the finish is extremely durable and repair was seldom needed. I am now looking to add this upgrade to my Catalina Caprin26 - and will tell you - If I had old slats on the walls, I would refinish them rather than make my own lumber as I did for the O'Day. That was extremely labor intensive. If you look up "New Ceiling in O'Day 26" on you tube you will find a short slide show of the project. Anyway - I would be interested in finding a source for pre-made lumber myself!
Chris Clark - Catalina Capri 26
Sep 24, 2018
4,648
I just sold my Oday 25. I understand the "joy" of the burlap sack
