Hi all! Lauren here––new Beneteau owner. I'm prepping my 1990 Beneteau M500 for a Pacific crossing. I want to add a macerator pump and plumb a holding tank to dump overboard, but want to make sure I don't sink the boat when I do it!
The old owners (who circumnavigated) removed all but one head holding tank. However, the holding tank's only discharge is to a waste pump-out plate on deck. When offshore at a legal distance, we would like to be able to dump our tank straight overboard so we are not tethered to places with pump-out services. Therefore, I'm looking into adding a macerator pump and wye-ing it into our existing thru hull. That said, the thru hull is below waterline, and the tank is at roughly the same level, perhaps slightly higher, so I want to be careful about siphoning/backfilling the tank.
I think my plan may best be understood with diagrams. I've attached a diagram of the current setup and a diagram of my proposed setup (new additions in green).
I have 2 main questions to make sure I don't sink!
1. I have read @Peggie Hall HeadMistress previous threads on adding vented loops to these tank dumping systems to prevent ocean water siphoning back into the tank. Can I replace a vented loop with redundant diverter valves that will remain closed at all times unless actively dumping out the tank? The tank is vented, but there are currently no vents in the hoses.
2. I currently plan to put an open Y connector at the tank discharge fitting (with a few inches of hose on either side––no hard on hard!). However, I'm wondering if this needs to be a valve instead of an open connector so that the macerator pump duckbill valves, etc don't get suctioned and inverted with tank pressure or pump-out suction. Are the pumps able to withstand that suction, or do I need valves to close off the pump on both sides?
Final question... the current hoses are all black corrugated sanitation hoses. What are the best connectors to cut and re-connect these to valves, etc? I worry that hose clamps might not get a good seal given the corrugated bumps. Links to buy connectors appreciated!!!
THANK YOU ALL!! Any help appreciated!
- Lauren
- Lauren
