Thoughts on locating Battery switch
Nov 19, 2023
28
Hunter 32 Vision Watauga Lake, TN
Hi. I'm in the midst of full electrical refit of my '89 Hunter. Am considering installing the new battery management in the place indicated by the paper template in the photo. You can see the original Perko A/B/Both switch on the left edge of the pic.
Moving it low will allow me to free some space in the engine compartment for better distro where I'm adding House bank bus and ground bus. Can anyone point out some reason I haven't considered for why this is a bad location?
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
I like to keep primary big wire battery systems out of the bilge. Things corrode faster and if you have a water ingress issue into the bilge, you could have problems…IMHO.
Nov 19, 2023
28
I agree Mark. But the factory wire path is already through those storage compartments and, though it's technically bilge-ish, there are no signs of there ever having been water in those compartments. Those compartments are a good 4" higher than the center-line bilge compartments. You can see the engine mount sleeper in the lower left (white under the A/B primary wires). That's a high and clear of the bilge water that's collected under the engine (which is a whole 'nother thing for me to figure out).
Jan 4, 2006
7,862
The wires in there are continuous with no terminals so no corrosion.
Where are the batteries now relative to your intended position for the battery switch ?
Nov 19, 2023
28
ok, good point. I was weighing the relatively low risk of high water (above cabin sole) against benefit of cleaner installation for distro wiring. This boat may find its way back to sea again (currently on inland lake) so your point is well-taken. One bad day in salt water would be more corrosive than a bad day on the lake.
Batteries are behind the bulkhead visible at rear of original pic. Accessible from aft port lazarette.
I built a board for primary distro to help manage the tight space. These pics show work in progress.
I'll be back on the boat tomorrow and will look for other/better options for the BMS and a four post distro in/near the engine compartment. A little voice in the back of my head warned me against the location I proposed. I'll take your point as a second and find another way. Thanks!
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
That location for the switch looks fine to me ... I wouldn't hesitate. Most batteries are located in a position just as low, so what's the difference when the battery terminals are just as low. I see that your batteries seem to be mounted higher in a lazerette but I see no reason why that makes a difference for the switch mounting. (What is the BMS in reference to?) It's good to have the switch mounted close to the batteries. My battery switch is mounted in an absurd location where the cables are stretched across the entire width of the boat. :huh:
Likes: Ward H
I rebuilt my Primary DC & AC panels with the help of a friend's CNC machine.
The AC panel is a Blue Sea ELCI GFCI Panel AC 5-Position #8101
The DC panel was cut out of a piece of ABS plastic.
Likes: Ward H
Nov 19, 2023
28
BMS - Battery Management Switch; perhaps I landed on that term from my own drawings/documentation. Sorry for being cryptic.
I'm using Blue Sea's Dual Battery Bank Management Panel (8690) to keep Start and House banks completely isolated, with the option to gang them if needed.
I paired this with an ACR at the battery banks to manage the charge current back to the otherwise isolated Start and House banks. The alternator feeds the Start side, but the ACR will direct charge to the House Bank as needed. Then when I'm in the slip, my Inverter/Charger hangs on the House side and tops up both banks via the ACR. Or it will, when this installation is finished in the next couple of days.
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
Better Meteorological Sailing this acronym found in Lloyd's acronym finder.
The alternator feeds the Start Battery, and ACR (when sensing threshold voltage on the Start Battery) feeds the House bank.
I thought the flow was a one-way street.
How is this managed "the House side and tops up both banks via the ACR"?
I have all charge systems feeding my House bank. When the ACR senses the threshold voltage, it feeds the start battery. When using the start battery, the demand for recharging is minimal.
Likes: Ward H
Nov 19, 2023
28
The ACR just uses voltage sensing to open and close relays (likely solid state relays, judging by the size of the device). So, as long as the battery banks are within operational range, the ACR directs current from House-to-Start or Start-to-House. Here's a drawing from Blue Sea that I based my design on:
[EDIT] Note that the ACR also senses whether you're charging or discharging and only combines them when charging. This keeps one bank from draining the other when there's no recharge current coming in.
Likes: LloydB
Wrong. It should go to the house bank which ALWAYS needs more amps than any start bank.
Plus that diagram doesn't show any switching...whazzup there?
I learn something new all the time. Just called Blue Sea Tech. He said the ACR senses voltage on both ends. When voltage is above 13 plus volts (check the spec for exact number) the ACR will send charge to the other battery in either direction.
BlueSea features: Dual sensing
I wonder if they always were wired that way?
Nov 19, 2023
28
If you'll read both the ACR installation manual and my previous post, you'll see that in fact the purpose of the device is to form a continuity bridge along otherwise isolated and parallel paths. Blue Sea calls them the A and B sides of this device. They are interchangeable. In my installation, the House is on A and Start is B.
So, in my case: If the charge current is coming from the alternator, it stays on the B side and goes to charge the Start battery, regardless of what A is doing. But if while in this state, it senses that the House (A) side is below 13.0v for more than 30 120 seconds, it will close the contact and direct incoming charge current to BOTH House and Start. The inverse is true when I'm in the slip and charging from my Xantrex.
Here's a grab from the manual/datasheet showing the thresholds that apply for 12v and 24v systems. This is what @jssailem heard from Blue Sea.
[Edit] - as for the lack of a battery switch, the diagram is meant to be informational, not functional. That's what the manufacture provides to illustrate one potential use case.
Oct 26, 2008
6,432
If you read Maine Sail's writings, he advises directing the alternator current and all other charging sources to the house bank and relies on the ACR to distribute current to the start battery since the need for charging the start battery is typically very low. I suppose if you are keeping your house battery in a near constant state of full charge, like many of us do thru the shore charging current, it makes little difference where the alternator cable is linked. I don't often rely on the alternator to charge my house bank. If you regularly discharge your battery during extended periods at anchor, or if you spend a lot of time on a mooring and you rely on your alternator to bring the house bank up to charge, then I would consider routing the alternator cable to the house bank side of the diagram.
BTW, I thought you might be referencing the switch with your BMS reference. In today's technology with LiFePo4 batteries, a BMS typically references a Battery Management System that is either an external or internal devise that monitors and safeguards the batteries. The BMS reference led to some temporary confusion! ;)
6,432
Also, I see that you are changing over to the DCP type switch for the isolation between house and start. I'm in favor of that change and have done it on my boat. However, you should be cautioned that the combined position, if ever used, may not be a desirable feature. Notice how the Combined position features a caution symbol!
If you have a catastrophically damaged battery or battery bank, you will not ever want to combine a functioning battery (bank) to the damaged bank or you risk damaging all. That is the downside of this switch. You cannot isolate a damaged bank and use the combined position to serve both house and start functions. (Well, you can if you completely disconnect the damaged battery first before engaging the switch). There is a more convenient work-around, though. Add separate On-Off switches between each battery bank and the DCP switch. This way you can switch off a damaged battery (bank) before engaging the combined position for house and start on the good battery bank. This is what I have done based on Maine Sail's advise. I put the On-Off switches in a concealed location right next to the batteries because the normal position for both is always ON until any rare instance where I might have a catastrophic battery failure.
Nov 19, 2023
28
This is good info to keep in mind. I hadn't thought about it because this is also the case with the BOTH position in my old Perko switch. The take away here is to know why you need to do something out of the ordinary before blindly taking some action that might make things worse. Something we can all stand to be reminded of. If I can't start my engine, I'll be investigating a bit before throwing the switch over to BOTH for the very reason you stated. Must not give in to the "easy fix" that might make it worse.
The difference between this new switch and the old one is that the Perko lets me choose either A or B to the single, common output, in addition to sending Both. With the DCP (Dual Circuit Plus) switch, that's not the case. I like your solution to put a disconnect switch for each bank, ahead of the DCP. I'll probably do that.
Until then, I'm happy pop off the positive cable on a bad bank, if it comes to that. One of my goals in this refit was to have clean battery installation with a single cable on each battery post. I'm handling all the primary bussing nearby on a panel I built for that purpose.
Forgive the slapdash overlay on this pic. I have a proper schematic but this was handy when cutting 1/0 and crimping lugs on the boat. In reality, it's much neater than this. Here's a draft of the overall installation.
Nov 19, 2023
28
I have based a lot of this design on Maine Sail's writing at Mareinhowto.com. But in this case, I elected to leave existing wiring harness intact - which means the Alternator charge current back feeds down the same path that energizes the starter. To preserve that requires that I keep the Alternator on the Start bank (single Group 24 battery).
My thinking was that the ACR should make the charging seamless for me. I leave the dock with both banks topped up. I will have about 700Ah (usable) in my house bank in the form of 2x 6v golf cart batts. If I'm over-nighting on the hook, and draw down the house, I can always run the engine to to charge it (while I make hot water too). At that point, the Start bank should be very near full, so the House will draw/sink most of the charge current via the ACR.
Now, to go throw a few bucks into Rod's tip jar over at Marinehowto.com.
Good idea. But it sure sounds like you're not reading and/or absorbing much of it
These come from my: Electrical Systems 101 Electrical Systems 101
OEM 1-2-B Switch Wiring History Alternator/Batteries & "The Basic" 1-2-B Switch BEST Wiring Diagrams
1-2-B Considerations (New 2020 - Rod finally got around to diagramming what I had done in the above link in 2009 :) )
1/2/BOTH Switch Considerations
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: Basic Battery Wiring Diagrams
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
http://forums.catalina.sailboatowners.com/showthread.php?t=137615
This is a newer primer for boat system wiring design with a thorough diagram: Building a Good Foundation (October 2016)
Building a DC Electrical Foundation
The Short Version of the 1-2-B Switch Stuff: Electrical Systems 101 This is a link to the Electrical Systems 101 Topic, reply #2
How to properly wire & switch a DCP switch - Maine Sail's "workaround" explained Replies #28 & 29
What size fuse for automatic charging relay?
Maine Sail's DCP Wiring Diagram
Operating the House/Start battery selector
AGM Battery Issues and the Blue Seas Dual Circuit Switch (from Maine Sail) "DARN AGM Batteries"
Darn AGM Batteries
What are ACRs, Combiners & Echo Chargers? (by Maine Sail) [scroll to the top]
http://forums.catalina.sailboatowners.com/showthread.php?p=742417 and Battery isolator / voltage regulator / batteries
Making Sense of Automatic Charging Relays (2019)
Making Sense of Automatic Charging Relays - Marine How To
Nov 19, 2023
28
One last post from me to this thread. I believe these forums serve as a good long-term repository of useful information for readers in the future. So in that spirit, I'll clear up a couple of things and bid my goodbye. I don't care to argue with zealots and trolls. This post will be a bit long. You've been warned. But I feel the need to make some things clear for posterity because there are people on this thread who delight in dogmatic bluster.
TLDR;
  • First, don't install a rocker switch where you might kick or otherwise bump it (see below).
  • Next, there's absolutely nothing wrong with the design of the DCP switch from Blue Sea Systems. Despite the deranged ranting of internet zealots who will tell you otherwise.
  • You must understand the use case, priorities and complete system design in order to fairly evaluate the appropriateness of individual components. Do this on a case-by-case basis. Otherwise you're at risk of being struck by a dogmatic cudgel.
Okay, on to the long form summation for MY USE CASE. YMMV. Read on if you dare.
First, I'll admit that I misstated how the ACR logic is applied to the open/close of the single relay (I'll go back and correct that post). But I maintain that the I fully understood the end result: Through the comparison of battery voltages, and the sensing of charge current vs. draw current (more on that in my post correction above) the ACR manages the status of the relay in order to direct charging current where it's needed. I thought is was using something like an H-Bridge when in fact it's much simpler, but enough on that here, see my edits on previous post for details (which I'll correct and explain after this lengthy post).
Having just come from a full and enjoyable weekend on the boat, I can definitely say that my original post about the location of the switch was a flawed proposal. It's debatable whether the proposed location needlessly subjects it to potential corrosion/water damage (probably). But what's clear is that I would have likely hit it with my heel a half dozen times this weekend, while getting in and out of the berth. Heel strikes on a rocker switch/breaker are obviously undesirable, so I'll mount the DCP elsewhere. (The panel in question has both a rotary DCP switch and a 100 amp breaker).
With that cleared up, I'll now address why the DCP is an excellent choice for my boat and my usage. I took a brief look at Stu's comments here and on other platforms and see that he's a zealot with an axe to grind against a number of things that include this DCP. And he has a fetish for Battery Switches which I find Creepy and Weird as Hell.
More positively, Scott T-Bird points out the switch can be a good choice for some people with the proviso that there's an understanding of the dangers of ganging a good bank with a "catastrophically damaged" bank. That's 100% correct and happens to be true of traditional A/B/Both switches as well. I have enjoyed a long and very successful career designing and operating broadcast television systems with resiliency and failure mode operations in mind, and I contend that in all but the worst and most urgent scenarios, users should have an understanding of the nature of a failure BEFORE implementing a recovery step or work around. Anything else is just shooting arrows in the dark. In this case, the question becomes how to identify the nature of your battery failure. I won't get into that except to say that I log my voltages every time I open up or leave the boat (from the meter on my DC distro panel). And once I put in my new house batteries, I'll measure internal impedance using ohm meter at regular intervals and track that over time. Those are health indicators that will establish a baseline.
The DCP (Dual Circuit Plus switches from Blue Sea) is meant to maintain separation between House and Start banks. It happens to also provide a way to gang those together (thus the Plus) - think of that mode as an additive Y-formation - and caries a warning printed in that switch position. This Y-formation is no different from the BOTH position on a traditional A/B/Both. Which is to say, that if you're relying on that position on either type of switch, you'd better understand what conditions have prompted you to do so, and with it what risks you're facing if you gang the banks. Again, see Scott's comments above on that. Keep a multimeter on board and know how to use it.
The way the switches differ is that an A/B switch has the additional ability to direct either A or B banks independently to your load, whereas you can't do that with a DCP. This is a feature of the DCP, not a bug. It certainly isn't applicable or appropriate for all boats or skippers. But it's definitely not a design shortcoming (as asserted by the zealot).
The traditional A/B/Both switch invites a 'try and see' approach to trouble shooting, which can be bad in the wrong hands.
Here's about as good a write-up as your likely to find on the subject of traditional A/B/Both switches. definitely go read it.
I don't think a DCP is applicable to a bluewater cruiser, or even to yachts with more sophisticated systems and complex needs. But I'll tell you why it's ideal for me, and perhaps for you too - only you can decide what's right for you (much to the consternation of those who would shove dogma down your throat).
My boat (not a yacht) currently lives on a small-ish lake. My overriding interest is the ability to start the engine and get myself home. My second priority is the ability to enjoy a couple of days on the water without ever having to think about how much battery I'm consuming from my house bank. In other words, if I run the house bank way down - that just means it's been a great weekend and it's probably time to head home. Of course, I can run the engine for some bonus time, but that's neither here nor there. The point is, I can enjoy myself, knowing that my start bank is waiting, safely isolated with a full charge. You don't need a DCP to do this. But you do need to manage an A/B/Both switch a bit more carefully in order to revel in this carefree operational mode.
Now, let's look at some failure scenarios - FOR ME, ON MY BOAT. Let's assume that I leave my slip with both banks fully charged.
  1. The most likely failure scenario on MY BOAT (as it was wired when I got it) was if I left the dock with the A/B/Both switch set to BOTH. This would clearly be my fault - operator error. But it's very easy for this to happen because my shore power charger was wired to the COMMON pole of the A/B switch, (as was my alternator) so the only way to keep both banks on charge was to set the switch to BOTH. That's a common way for these to be wired. Now, there are a few other ways to re-wire this to help me avoid the need to use BOTH for charging, but that was the state of things before I redesigned my electrical system. Obviously, spending the weekend drawing down BOTH would be a boneheaded move. Yes, this can be managed through a series of steps to change the switch position every time I start/stop the engine or leave/return to slip. Failure analysis experience tells me it's a bad idea to require that much fooferaw in order to transition between 'modes of play' - it's appropriate on a flight deck, for example. But I don't need to prove anything to my guests on board (or myself). I choose the K.I.S.S. principle. ADVANTAGE: DCS
  2. Discharge of one bank. If for any reason, either one of the banks is allowed to discharge below usable voltage, I've got another bank. This is the obvious and simple reasoning behind the A/B/Both switch. Clearly, if it's just a case of having overspent my time on the hook, I should simply be able to switch over to B side and use the start battery to run my Vhf, lights, starter, or anything. Of course, I can do that with the DCP by putting into its own BOTH mode (with the caution symbol on it!). But I'd better be damned sure that I've only got a case of over consumption, and not a failure within the House bank. ADVANTAGE: Toss Up. Both switches carry same benefit and require the same vigilance in this scenario.
  3. Battery bank failure (not discharge, but actual damage). There are a number of ways a battery bank can be damaged - all of which are well detailed elsewhere and not worth getting into here. But a damaged cell can take down every other cell that's connected to it. Clearly, isolation is key to maintaining a backup solution. DCP together with ACR go a long way to reducing maintaining total isolation. If I'm unaware of a damaged bank (on either side) and decide to charge both banks through the BOTH position of a traditional switch - or if I succumb to the temptation to gang both banks together to get more A/C current through my inverter (I know, don't do this, but if it's there as an option, it's bound to happen some day) I've exposed both banks to this potential failure scenario.
Please note that in scenario #3, if the damage happens to the START bank and I'm using a DCP, I won't be able to just throw the switch over to HOUSE and expect to motor home. Though, by adding a primary disconnect switch for each bank* as described by Scott, Stu and Maine Sail/Rod/Marinehowto, I can use the BOTH position on DCP to send HOUSE only to both outputs (outsmarting the DCP) because I will have disconnected the bad START bank. ADVANTAGE: Toss Up. Potato/Po-tah-to.​
*I'll note that I'm more likely to forego adding two switches and just use a 1/2" nut driver to remove the positive wire from a failed bank if needed. This is because my battery installation is somewhat cramped, but very neat. Mounting two switches and adding the requisite 1/0 battery wire is going to make it even more crowded in that lazarette for a tiny convenience of throwing a switch in a very low probability situation. I can way more easily reach for a nut driver and pull the wire off the terminal. The other reason I'm likely to do it this was because this particular boat has my name on the Title.
There are likely other failure modes that I'm not considering here. I'm sailing around a lake, not setting off for Perth or Penzance. Similarly, across all aspects of my life, I don't own anything that could be considered to be, or is marketed with the word "Tactical" since I don't intend to invade any countries or plan to do any LARPING. If a troll on the internet is telling you there's only one method for all use cases, they're probably wrong and probably a zealot.
There are compounding issues to be considered. The most glaring one to me is the possibility of damaging my alternator in scenario #1 above. If I've got the engine running with the intention of charging banks, I'd better have started it with the switch in the appropriate position. There are certainly steps I can take to remedy my mistake, but the concatenation of mistakes tends to ratchet up the probability of further mistakes, leading to higher stakes with each iteration.
Of course, the DCP works best in combination with an ACR. I know and understand why Maine Sail is a proponent of keeping the Alternator on the HOUSE bank when designing a dual circuit system. However, I would counter that with two assertions:
  1. In retrofitting scenarios, that requires separating the Alternator from the Starter, as they're commonly wired together on a single branch on many factory harnesses. I will likely rewire that part of the harness some day, but for now I prefer to leave them together.
  2. Once the ACR has bridged the two circuits, a charge current on either side is as good as one on the other side. In other words, if that relay is closed, the electricity does not differentiate between HOUSE and START banks. The hungrier bank (that is, the one presenting lower impedance to the charge source) will draw proportionally higher charge current. If you need something more sophisticated, you're likely running LiPO batteries and a candidate for a true Battery Management System that can regulate charge currents and voltages. None of that is applicable in my installation.
All of this is a very lengthy treatise on things that Shouldn't happen. And situations that Should be manageable.
But there's one last point I want to stress about why I made very well informed choice to design my system for my boat so that I can manage it the way I please. My boat happens to have come with two DC distribution panels. There's the factory panel from Hunter, with 10 DC breakers, a fused position and janky SPST switch someone threw in (soon to be removed!). But there's also a Blue Sea panel with 5 more DC breakers and volt meter. And with my professional background, I recognized a design opportunity that suits me very nicely.
I have designated that 5 position panel as my Critical Loads Distribution Panel. I'll move all nav lights, my instruments and my VHF to that panel. The factory panel will have all cabin lighting and convenience loads and perhaps refrigeration, some day on it. It also happens to have A/C distribution on its other half too. So, if there were ever a problem on that panel that can't be solved with the throw of a breaker, I am not pressed to dive into it. I can take that whole panel off line and keep my Critical Loads powered via a separate path, either on their default House Bank, or they can be directed to the Start Bank with a simple transfer switch. Now.... would I have designed it that way from a blank sheet of paper? No, probably not. But since I have the two panels, that's the way I'm going to use them. With this design, I don't HAVE to be able to direct my START bank over to the HOUSE side in order to make use of VHF and Nav lights. I certainly CAN do that, with the precaution stipulated above. But I also have the further option of EASILY directing the Critical Loads to the START Bank if necessary. That's a very different paradigm that results in a different way to reach the same desirable outcome.
I haven't gone to lengths here to tell you what you should do on your boat. I'll leave that to the zealots. I have tried to describe here ONE way of doing things that is electrically correct, and offers some options to this skipper of this boat. As with any tool, you must know how to use it and understand the dangers inherent in its use. Don't let others prescribe solutions for you based on dogma and zealotry. Inform yourself. Learn. Understand. And consider your needs as only you can. Then take the best of everything you've learned and make some informed choices about what's right for you.
Likes: Ward H
