Has anyone worked this material? I'd like to put it on the hull interior walls. I've removed the thin layer of "luwan" (⅛ inch plywood) that was glued to the hull. Do you think I can stick it directly to the fiberglass or should I replace the luwan board to create a vapor barrier?
