Hull interior
Aug 11, 2011
1,020
O'day 30 313 Georgetown MD
I have used this product, not inside but outside. Over a two year period with the boat in the water I found the following.
a) it will keep every little pit mark given to it. It also rips easily.
b) it is not UV resistant. It breaks down into a fine dust
c) it is not water resistant, it acts more like a sponge.
I removed everything from the outside and replaced it with SEADeck. ( picture showing gray product)
I have it in one place inside my boat, namely on the inside of my deck hatch/port to hide the bad spackle and paint job for the moment until I do some major cosmetic upgrades.
I have a lot of left over pieces if you want them, you would invest in the shipping to you.
62
O'Day 22 Redlands, CA
Has anyone worked this material? I'd like to put it on the hull interior walls. I've removed the thin layer of "luwan" (⅛ inch plywood) that was glued to the hull. Do you think I can stick it directly to the fiberglass or should I replace the luwan board to create a vapor barrier?
I'm looking for something attractive for the walls of the hull. Thank you for o I'm not sure if the light gray would be my
Thank you for your generous offer. How much do you have, in terms of Sq. Ft?
I have not used the "Peel&Stick" material.
There are considerations regarding materials used to attach to hulls. Moisture and condensation can be an issue. Just like house walls, you need to consider a vapor barrier, air space, and insulation. Open-celled foam will capture and hold water like a sponge. If you air condition the inside of the boat, humidity and temperature differences may contribute to condensation on the sides of the hull. Check with the manufacturer regarding the issue. Note that you are installing the material inside the hull. UV damage would not be an issue.
Likes: BigEasy
Aug 11, 2011
1,020
I will need to lay it out and get back to you with the number. I'll give you Sq. Ftge of all the big pieces, but you can have all the "scraps" as well.
Sep 24, 2018
4,567
Catalina 30 MKIII Chicago
I thought long and hard about this material and ultimately decided against it. Installation will be difficult due to the lines. Getting them perfect is an uphill battle.
I ended up buying some canvas with no backing. Bad idea. You could see fiberglass print through. We ended up installing some foam under it. Not the greatest idea but it's what we had on hand. I would recommend something with a backing and/or carpeting. It'll hide the imperfections which will occur, no matter how careful you are.
As for glue, we started off with 3M 70 and 90. Great product but terrible coverage. After spending $100 on glue for one wall, I sought out alternatives. I bought a dozen cans of V&S 1081 headliner adhesive. We used maybe 2.5 cans on one wall. 3M has maybe a 15% better spray pattern but the amount of glue used was substantial.
Masking everything off took an hour or two per side. Masks and a second pair of hands are essential
