Just picked up new to me 1988 Catalina 25 on a trailer. I'm believe I'm the 4th owner. The PO didn't really understand sailing or boat maintenance and the owner before him was an older lady that either didn't share or he didn't know the questions to ask. We believe the boat has been in freshwater all her life. We don't know the last time the bottom was painted or the type (if any) barrier coat that was applied. There was apparently some work done on the lower bow, I waS told dock rash. Hopefully, the pictures will help us understand what has been done and the next appropriate steps.
I believe I need to do the following. Please provide recommendations/guidance as appropriate. I plan on doing the work myself.
1) Apply barrier coat
- not sure if there was a barrier coat but from the pictures of the point of the bow I'm assuming the white gelcoat is covered/painted by a light grey coat (barrier ???) and then a darker gray layer (bottom paint ???) . The darker gray layer actually looks like the blue bottom hull color further along the boat. The exterior of the boat (above the waterline and below the waterline look excellent and smooth; obviously above the waterline is smooth like glass but below the waterline it's still smooth).
- do I need to sand down to the white gelcoat looking layer (I would prefer not to damage or harm the existing layers as they look really good but on the other hand I believe I need a barrier coat since the boat is a 1988 and it appears as if nothing has been done since)
- I'm assuming I would sand up to the bottom on the blue stripe below the red boot stripe?
- use a quality epoxy barrier coat and following vendors instructions
2) Apply bottom paint
- use a quality bottom coat and follow vendors instructions
3) Polish the gelcoat above the red boot stripe to the cove stripe below the rub rail.
Sure appreciate any advice/guidance ya'll have. I'm operating in the dark here and appreciate ya'lls knowledge and experience. Thanks in advance.
