I just couldn't figure out what else can cause the reversing issue. Gone down to check the Kiwiprop and it feathers easily forward and backwards as I turns the prop shaft by hand.@Ken13559 ,
Ken, do you have a theory as to why the low compression may be what is preventing the transmission from shifting into reverse ? I fail to see a relationship between the two, but that's just me.
Keep us informed of every detail on the mechanical problems as you go along. I can imagine how you feel. It seems like a lonely, miserable, SOB right now but we're all with you on this.
I will try checking & adjust the Tappets gap but doubt that to be the issue. I plan to change out the Kiwiprop to original fixed 2 blades prop.
2 scenario here:
1. if reverse is still a problem, then engine has really weaken. Some years back the compression test shows about 250psi, which is lower than spec 350-450psi.
2. if reverse is not a problem with 2 Blade prop, then it still mean the Engine is a problem because I've been using the Kiwiprop for so many years without any issue.
Doing the 5-Why still points to engine issue.
I'm ranting here.....
