1. I've never had this problem before. But 2 weeks back, starting engine after sailing it gets overheated with alarm. Found U Mixing elbow hot. Pull out the SCW hose to pump to clear any airlock, then start engine and pull out the hose at heat exchanger inlet to make sure SCW is flowing then engine runs normally.
Thereafter I have checked all the hoses from water inlet valve right through to U Mixing elbow and couldn't find and issue. I even removed the Anti-Siphon valve for blow & suction test. All looks good BUT still engine gets overheat each time i start it. What gives?
2. Engine could not reverse normally. I might have damaged the gearbox last year when i shift engine into reverse while tie to the dock against a fast flowing river water. Engine reversing was trying to push river water back upstream! My mistake. After that whenever i shift to reverse, the engine gets loaded with black smoke and I need to shift to neutral, forward then reverse again before things works.
Now, one year later, engine totally won't do a sub-normal reverse (as described above), it will laboriously turn the prop very slowly puff out black smoke. I guess the gearbox is shot. So what broke in the gearbox? Any idea?
Thanks.
Thanks.
