At the risk of sounding like a newbie, which of course I am. I would like to know what the toilet brush on the top of my mast is for
www.practical-sailor.com
Stored up there, you'll always be able to find it.Or it could be a real industrial toilet brush for cleaning the commode at a truck stop.![]()
While it may not be proven to be effective, it can't hurt to leave it there. My boat had one, and, for almost 20 years, never received a lightning strike.Wow! Ok thats cool. Much thanks for the info. Hope it does work to at least some degree
What? I was hoping it was a key to the Bermuda Triangle. Now that would be cool.Im pretty sure the wire brush doesnt do anything bad.
Thanks to all who have contributed. Some funny ones but also some really interesting and hood links. Lightning is one if those things to keep in mind as I have come across two boats so far that had lightning strikes. Much thanks to all. Zom-B outAt the risk of sounding like a newbie, which of course I am. I would like to know what the toilet brush on the top of my mast is for
Like always bear hunting with an overweight friend, you only need to outrun your friend not the bear.Interesting because if you are in a marina, you want your neighbors sailboat mast to be a slightly more effective lightning rod than yours
I've never had lightning protection in 40 years and have never been hit by lightning.While it may not be proven to be effective, it can't hurt to leave it there. My boat had one, and, for almost 20 years, never received a lightening strike.
Hair stands up because the follicles hold onto electrons and electrons repel each other, so they stand up as a way of getting the farthest away from each other as possible. By getting wet in salt water, you may have created a liquid Faraday cage that meant the electrons traveling through the conductive water over your skin couldn't move towards the inside of that saltwater shell that coated your body.another strike resulted in tingle of the legs and my hair standing up again.
I think the idea is that carrying the current down in a straight line is the best. That much current doesn’t like to make turns. You also don’t want to build a configuration where the current is running on the perimeter and then tries to jump to the keel or mast across the interior.Hair stands up because the follicles hold onto electrons and electrons repel each other, so they stand up as a way of getting the farthest away from each other as possible. By getting wet in salt water, you may have created a liquid Faraday cage that meant the electrons traveling through the conductive water over your skin couldn't move towards the inside of that saltwater shell that coated your body.
I don't know, nor have read much about lightning protection on boats, but it always baffled me as to why you would run the conductor down the mast and to the keel through the center of the boat. Wouldn't it make more sense to bond the keel plate to the outer shrouds and stays so a masthead lightning strike would more likely encourage the electrons to stay outside the interior of the boat? Wouldn't the conductive stays create a Faraday cage around the sensitive equipment and lives inside?
-Will
We had a boat with one of the tallest masts in the harbor for 24 years and never received a lightning strike. We didn't have a "dissipator". Banging pots with spoons is supposed to keep bears away. Worked in our apartment in New York for as long as we lived there.While it may not be proven to be effective, it can't hurt to leave it there. My boat had one, and, for almost 20 years, never received a lightning strike.
Well, yeah, that was my point about the Faraday cage approach. The problem, I see, with bringing the charge to the interior, is it may decide to pull from multiple points, like the engine and battery grounding to relieve the potential that a single heavy ground wire can't do. There's a LOT of wattage in a lightning strike and even if it went straight to the keel, it could still burn a hole through the interior along its way. The Skin Effect uses that potential to keep the charge out of the interior.You also don’t want to build a configuration where the current is running on the perimeter and then tries to jump to the keel or mast across the interior.
