Boom kicker or topping lift?
Hmmm.... I'll have to think on that. I agree that the vang is most important when the traveler block is at the end of the track but when I am on a run, I don't think of the vang as inducing any twist in the top of my sail (why would I want to do that ???) but rather it holds my boom down and keeps it from riding up.
That’s correct - on a run the vang prevents the sail from twisting forward too much. The “riding up” you mention is just the visible effect of that twist on the height of the boom.
capta
Jun 4, 2009
5,006
I like a topping lift. it can be used with the boom as a crane (I've pulled many an engine this way), or as a very quick way to let the wind out of a sail if needed. I've pulled dinghies aboard this way too.
I have a Selden Rodkicker, which is sold with an "optional" gas spring. The rodkicker simply slides out when I release the tackle as I try to dial in proper twist. I haven't noticed any particular springy action, but it seems like the wind alone will lift the boom to provide twist. But maybe not enough? I suppose it's possible that there's an old worn out gas spring inside that is completely shot. With winter haul-out coming, maybe I should just pull it off to install a spring for a winter upgrade that I didn't know I needed.
A vang controls twist by reducing it. Off the wind, the boom's natural tendency is to rise allowing the top of the sail to twist off and depower. The stronger the wind, the more twist that is induced. The vang (all vangs regardless of rigid or soft) applies downward pressure on the boom which flattens the sail and reduces twist.
When running down wind and approaching a broach, releasing the vang will immediately depower the main and help to get the boat get its footing.
I have seen what you are describing... and I suppose it is just like twist but in an exagerated way. I guess I never thought of the boom riding up as "twisting" the sail. When sitting in the cockpit on a run, you are not looking down the leach so to my eye a rising boom acts to induce a crease about half-way up the sail that dumps most of the wind.... and you are correct, it will depower the sail. I suppose if you were looking down the leach, it would look just like twist.
Jan 7, 2011
5,858
Oday 322 East Chicago, IN
Topping lift is a problem for those with large roaches (as here in Louisiana? :yikes:)
My new sail was cut a little too big, and the headboard catches the topping lift every time I tack.
I am considering a rigid vang of some sort (my previous boat had a book kicker) Just to eliminate this source of chafe.
Greg, is it catching the topping lift or the back stay?
There are some boats, I think 6 Meters are an example, that have a short batten off the mast head to hold the topping lift away from the sail. It sticks out maybe a foot. That may be a cheaper solution.
Likes: Mak41
I think the normal solution is just to leave the topping lift slack when sailing, so it doesn’t matter if the roach touches it - the TL just bounces around. Some sport boats have a batten to hold the back stay faster aft so it doesn’t catch as much.
Oct 6, 2007
1,164
Hunter H30 1982 Chicago IL
The roach of my main used to snag/chafe on the topping lift which was also set up in a way that was difficult to adjust. Annoying in every way. I replaced it with a Garhauer Rigid Vang about 12 years ago and am glad I did. No more roach snagging/chafing, it supports the boom when raising/lowering the main, lifts the boom when I want more draft or twist in the main, and pulls the boom down when I need to flatten it. All my control lines run back to the cockpit for quick, easy & safe access.
As others mentioned, I also use the main halyard like a topping lift when not sailing to lift the boom a bit higher for cockpit headroom, limit boom movement, take load (and long term spring compression) off the lift tube, and to prevent halyard slap.
There is not a topping lift made that can lift you out of your “roach” problem.
In your neck of the woods they have lived since the Dinosaurs, and will be there long after we all have been swept away.
Apr 5, 2009
3,211
On my boat, I use a ring in my topping lift to hold up the aft end of my sail-pak. Question for those of you who have a rigid vang and not topping lift with a main sail pack. How do you support the aft end of the pack?
RoyS
Jun 3, 2012
1,742
No knowledge about rigid vangs because I have always had a topping lift. I use the topping lift to temporarily lift the boom when I have to reef. This makes it easy to bundle up the sail with the reef lines. I don't know so I am asking; will a rigid vang do that?
Yes it can but… not always as easily as a topping lift.
Some boomkickers/rigid vangs use gas pistons - some use springs. They can be set to give your boom a positive angle when at rest. Of course this does not work for sailing, so the unit uses a block and tackle to pull the boom down to level as a standard Vang is designed to do.
You can of course guess, the gas in the piston can fail or the spring can wear out. They are not maintenance free. But what is. They do free you from having the topping lift halyard from flapping in the breeze.
All depends on how you choose to rig your boat.
Apr 5, 2009
3,211
... This makes it easy to bundle up the sail with the reef lines. ...
START :cowbell:
I never tie in the reef points. (small lines along the bottom of the sail) My main sail is about 18" shorter on the hoist and 6" shorter on the foot than it should be. It also has an old unused partial reef patch that ends abruptly at a horizontal seam with new 1st and 2nd reef patches above and below. There are also a bunch of needle holes at the clew that show the outline of a previous clew patch that was removed.
It was that way when I purchased the boat so I do not full history but it is obvious that the sail had an 18" horizontal strip cut out of it and then was sown back together and the trailing edge cut back 6" from there down to made a clean line. As I said, this horizontal strip is just above the original reef.
If you have the reef points tied in and for any reason, the reef clew or tack lest go it will tear the sail in two and you also can have a main like mine.
END :cowbell:
Now back to our regularly scheduled programing. :biggrin:
Aug 17, 2013
1,090
Pearson P30 202 Ottawa/Gatineau
This thread is getting interesting, I’m learning a lot, but what I really want to know is how simple is it to add a topping lift versus adding a boom kicker?
Apr 5, 2009
3,211
It just takes a trip up the mast (or bring the mast down) so you can attach the top end to the masthead.
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
Adding a topping lift may involve adding a sheave to the masthead if there isn't one where a kicker is adding a bracket to the bottom of the boom and an attachment point at the base of the mast.
Simple... depending.
It is all about what you have at the top of the mast and what you do not.
dLj
Mar 23, 2017
4,760
Better to have a sheeve at the mast head, but I used to have a boat that didn't, the mast head was fixed and if you wanted to adjust, you did it from the end of the boom. So actually it's quite easy...
dj
The topping lift is easier and cheaper and more budget friendly if the mast is down. A line down from the mast head, a couple of blocks and a cleat and you're good. The line can be light 5/16" will work because there is not much force on the line.
