Hello all!
I bought a widgeon this spring, and have used it several times. The centerboard gets jammed in the case if it is pulled up all the way. The only way to get it back down, is to try and stomp on the handle several times, to dislodge it and drop it again. How do I fix this problem? I already climbed underneath and check up in the case with a flashlight; all I found was some mini barnacles on the lower part of the CB. It looks clear all around it.
Any ideas on what could be causing this? Or how to fix it?
Thanks in advance!
Thanks in advance!
