Hey all,
I've read many of the threads on motors and so far, so I'll sum up what I've learned specific to a first generation Catalina 22 (mine is 1984) and my only ask now is if anyone knows of any red flags for this specific model: a Mercury Sail Power 5HP 20" (Long Shaft). The motor on my newly purchased Catalina is the only thing that might prevent me from getting on the water, and I found this one in stock and it seems to satisfy all the requirements.
Here's what I'm hearing as a consensus on concerns:
Here are some pics of my Evinrude that came with my boat. Dated the model number to 1985.
I haven't tried to start it up yet, but hoping to this weekend.
- Gas vs Propane vs Electric: Gas motors are a well-known commodity, you'll find gas anywhere. Propane and electric are more environmentally friendly, but have their trade-offs.
- Horsepower: 3hp to 6hp is the range you should be considering. Much more and you're wasting money and not getting any more speed. Much less, and you're limited to still lakes. 5HP vs 6HP generally favors 6HP because they are typically the same weight.
- A Long Shaft (20" shaft) is the sweet spot: a short shaft with an adjustable motor mount will likely get into the water, and sometimes an Extra Long / Ultra Long (25" shaft) may sometimes not come completely out of the water (depending on your mount). I measured the top of my mount (where the clips hang on) to the bottom of the boat (the transom) and in the upper position, it is 2' 3" (27 inches), and in the lowered position, it is 1' 2" (14 inches).
- A "sail" model like "Mercury Sail Power" or "Tohatsu Sail Pro" includes an alternator and can charge your battery for you.
- Other considerations? It sometimes might have a larger handle? Not sure
- Electric start? With a brand new motor, I am comfortable that this is not going to be a concern. My Mercury on my Pontoon started on the first button press, and I suspect any new motor will perform the same.
- Remote control? I don't see the need for this, but I suppose if I could control the throttle at the tiller, that would be convenient. If not, do you have to sit between the throttle and the tiller and control both of them?
