Key to main door
Udi
Mar 23, 2021
91
Hunter 45 ds 2010 Jaffa
Hi !
As a new hunter owner, I have two questions.
1)Any idea how can I get an extra key to the cabin entrance door (Hunter 45 ds). I didn't find anyone that can duplicate it.
2) As the two "stern 10" cleats" are located in a very uncomfortable location, I am thinking of moving it to a better position. does anybody have an experience with that issue, or any recommendation where should I move it.
Thanks for any advise on both questions.
Udi.
Did you try a locksmith? They have a wider selection of blanks than most hardware stores.
Not sure where you find them uncomfortable on the boat. Looking at images of the Hunter 45DS, I see the stern pulpit provides seating in the corners. Is that the issue?
Note the goal of the cleats is to hold the stern in place next to the dock or as is often the case in the Med to tie the stern directly to the dock so you can step off the stern on to shore.
Having the cleats at the stern and wide makes this possible.
Perhaps pictures would be helpful.
Likes: LloydB
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
.............1)Any idea how can I get an extra key to the cabin entrance door (Hunter 45 ds). I didn't find anyone that can duplicate it............
Congratulations on your new sailboat!!
With the key number you can purchase replacement keys here. That where I purchased replacement keys here for my Perko lock, since I could not find a locksmith who carried these key blanks. These guys make keys for trailer, rv's and boats.
EasyKeys.com - File Cabinet Keys, File Cabinet Locks, Desk Keys & Locks, Cubicle Keys & Locks, Key Blanks, Padlocks, and more!
Udi
Mar 23, 2021
91
Till now no locksmith had a solution. but I don't loos faith.
Thanks.
Udi
Mar 23, 2021
91
Udi
Mar 23, 2021
91
Hi!
As you can see there is no room for the cleats at the usual place because of the pulpit and the rest os seating area.
At the present position of the cleats the approach for tying is much harder than other boats I know.
I thought of moving it to the area marked at the photo but I am not sure that area is strong enough.
wondering.....
Thanks.
6,060
wondering.....
Different model boat here, but as I did with our boat, I posed the question to the manufacturer as to the strength of my desired location. Unsure from your picture, but to me it appears it does not have the reinforcement needed to support the stress of a cleat. Cleat loads can become quite heavy. Can you describe what is behind the area in question?
Udi
I suspected as much and your photo confirms it. You have a lot of stuff around the cleat making it difficult to access.
As you consider the options for your cleat, you should consider the engineering factor of a cleat. It's strengths and weaknesses.
BoatUS did an interesting write up that might help as a guide in your decision making. xhttps://boatus.org/findings/16/
Looking at your picture and the place you are considering, cleat failure could be by the fasteners pulling through the fiberglass. Cleats are designed to resist shear force.
The first three images in this picture show the cleat resisting shear. In the last image 45/45 vertical the fastener bolts are holding the cleat trying to resist the force. If the cleat is attached by a bolt and nut with a fender washer (as is so often the case), then the forces to hold the boat in place will try to pull the nut an defender washer through the fiberglass. Unless the fiberglass is exceptionally strong it will fail over time.
The way you have the boat secured to the dock your current cleat is using the engineered strengths of the cleat and the fasteners.
Placing the cleat where you are suggesting puts all the force on the fiberglass and the backing of the fastener. Not the engineered strength of the cleat.
I would not choose that cleat location for my boat.
One possible solution is to clear the area around the cleats and use the area only for access to secure your cleats.
Feb 21, 2013
4,638
From the 45DS owner's manual below the stern cleats are part number 9. I would not relocate them. They look pretty accessible in my opinion.
Likes: JamesG161
Looks like there are a long cord and a folding gang plank obscuring the access to the cleat.
Udi
Mar 23, 2021
91
As I recall from a look that I took of that area its almost the same as the area of the present cleat. Tomorrow I'll take another look and will take a picture of that area in order to understand better that choice.
Udi
Mar 23, 2021
91
The folding gang plank is an added problem, but the solution for that is easy.
The access to the cleat is hard with or without the gangway at the port side.
Udi
Mar 23, 2021
91
Hi !
it is indeed part# 9 and from my experience with other boats and also with that one its not a very comfortable access.
Thanks anyway.
Udi
Mar 23, 2021
91
Udi
Thats exactly my concern. changing the cleat position may weaken the cleat ability to hold the boat secure to the dock.
I'll take a look at BoatUS write about that matter.
In any case I'll take your advise concerning the stuff around the cleat.
I'll also try to get in touch with Marlow-Hunter engineering to have their opinion, even though I am almost sure they won't like the idea
6,060
Hi Udi, if you decide in the end to relocate the cleat to the new spot, be sure to back the cleat with an oversized plate washer in order to spread the shear/vertical load that the FRP bulkhead will receive. Also, the corner where that bulkhead joins to the transom, is it heavily or lightly tabbed or what type of joinery did MH use? If lightly, that could become a point of stress failure unlike where it is currently located.
If MH advises against that location, we hope one would take their advice and leave the cleat where it is and find a way to accommodate. It appears from the picture that the current location provides a better shear load strength than the new location, which seems to have a more vertical load placed on it.
JamesG161
Feb 14, 2014
8,092
Hunter 430 Waveland, MS
There a many ways to berth a boat without using those cleats.
For our home berthing, we use a pre-done line that can be looped over the stern cleats, by hand or pole, from the dock.
Jim...
Udi
Mar 23, 2021
91
Hi!
I'll consult my local shipyard, but I'll take my final decision after I'll have an answer fro MH.
thanks very much for your advise , it helped a lot.
thanks again.
Udi.
