I have a 88 hunter legend 37. I had the boat moved right after purchase and after the marina put the mast back up I began having a problem with my jib halyard. Whats going on is; I can pull the halyard from the jib end and it pulls ok. but when i try to pull from the other end to raise the jib it immediately jams and wont budge. Its not just in one area. I can pull 5 ft one way and cant the other, so now I have l a lot of slack from the mast down and about 10 ft before i Ioose the other end into the bottom of the mast..Without climbing the mast, has anyone else had a similar issue or an idea of what is causing the problem. All other halyards and sheets work fine
