Finally got the boat to the ramp this year and broke the base of the mast because I forgot to connect the shrouds in step 2 of the mast raising ceremony:
The baby stays were on, but without the shrouds connected the mast keeps going until, BANG! Both sides. Ugh. Fortunately, no other damage.
I resisted the philistine impulse to just blast away with more rivets, I mean, it would defy my principles to not pursue every possible, more expensive, time consuming alternative.
So I thought about TIG welding a patch on each side and called a welder experienced with welding aluminum (pontoons). His advice was "don't". 1) Heat anneals the Al and might make the area around the patch soft, 2) He would have to grind off the anodize to keep the arc happy (grounding). In addition, @Crazy Dave Condon cites Hunter directives against this, and @CloudDiver has warned of the perils of welding extruded aluminum. Still, I might be willing to send the rig off if there is technology available to overcome these pitfalls.
Thought about sawing it off and starting over, but that's complicated by shroud length, boom height, sail luff length, balance, rake, and probably the position of the moons around Pluto.
So am I looking at a replacement? Or should I cave to my uncultured instincts and blast away with more fasteners? The vessel is insured, but are they responsible for my inability to follow directions?
