ANL Fuses
May 2, 2012
276
Catalina 310 Toronto, Ontario
IZTOSS 2PCS 250A In-Line ANL Fuse Holder with Fuse.
Install Bay ANL250-10 - 250 Amp ANL Fuses
Has anyone tried these out. There seems to be quite a discrepancy price wise between these and Blue Sea.
Cheers
2 Old Pirates
11,669
Cheers
2 Old Pirates
Please avoid the use of no-name ANL fuses that are not IP rated. You also want toavoid them because they may not even be a true ANL in terms of trip-delay curves. They may actually trip near instantly when trying to handle motor in-rush loads.
The Blue Sea ANL product is the only one we tested, on dead short circuits, that has not failed in an unsafe manner. For the ABYC High Capacity Battery Committee we tripped close to 100 different fuses and every single one of the elcheapo "auto stereo grade" fuses failed in an unsafe manner by blowing the crappy window right out of the product. Not a single BSS fuse did this.. You get what you pay for with ANL fuses.
If an ANL manufacturer can not provide an IP rating and a trip delay curve for the fuse walk away..
May 2, 2012
276
thanks thanks thanks ...... that's exactly what I was wondering. When you see such a difference it makes you really think twice. Just had additional question. Does the holders fall into the same category.
Much appreciated
2 Old Pirates
11,669
Much appreciated
2 Old Pirates
Absolutely. Blue Sea has two fuse holders for ANL 35A to 300A and 35A to 750A. These are extremely high quality fuse holders thoroughly tested and abused. They are solid nickel plated copper to resist corrosion and have full encapsulating polycarbonate covers. The only other ANL fuse holders we will use at our shop are the Marinco Pro-Installer Series...
Likes: Alansails
Nov 16, 2012
1,041
Cheers
2 Old Pirates
Why those rather than MRBFs? Just wondering. The MRBFs worked great for our upgrade.
Mar 20, 2016
594
Beneteau 351 WYC Whitby
Eaton Bussman , ANL fuses are an Industry standard and if were a betting man they produce bluesea's they look Identical.
RoyS
Jun 3, 2012
1,742
Be aware Blue Sea's factory was severely damaged in a fire allegedly set by a disgruntled former employee. Many items that I ordered this season are showing up "backordered". I have no idea when delivery may occur.
May 2, 2012
276
Close to finishing setup. When it comes to BusBars could I use these.
T Tocas 300A BusBar Box - Heavy-Duty Module Design Power Distribution Block with 4 x M8 Terminal Studs
4 studs (5/16"),Removable windows for unobstructed wiring
  • Max Amperage: 300 Amps at 12VDC per connection
  • Max Voltage: 48V DC
  • Reinforced Polycarbonate & tin plated pure electrical copper
  • Dimensions (L x W x H): 138 x 69 x 44.5mm (5.433"x2.72"x1.75")
Cheers
2 Old Pirates
11,669
It will probably work, but I don't know why you would want to choose a mystery supplier, plated brass not plated copper, over a known quality busbar such as the Blue Sea 2127? From what I see the Chinese busbar actually costs more than the 2127 and appears to be a knock-off of the BEP product....? The spec says 300A max and the Blue Sea is 250A continuous but I know Blue Sea is using legit testing facilities and I have no idea who is testing and rating the Chinese busbar.
JRT
Feb 14, 2017
2,048
@2 OLD PIRATES can I ask what this is about? Is this a change to the C310 or replacing something that needs to be addressed. Still learning my C310 but I can't remember seeing any of this setup in my boat. I'll have to look closer at the new GC 6V battery area, but it was super neat and cleanly done with no issues identified.
Nov 16, 2012
1,041
JRT, he is upgrading his batteries and wiring. Adding the bus makes connections easier, and moves them off the battery terminal-where only 2 (?) connections should be made.
Likes: JRT
JRT
Feb 14, 2017
2,048
AH, I'll look closer at this area next time on my C310
May 2, 2012
276
Here is another odd question. Can you add a Mounting bar with fuse to a Busbar?
Cheers
2 Old Pirates
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
Before or “after”, yes. Before would be subject to distance ‘upstream’ for protection purposes of that feeder.
Ward H
Nov 7, 2011
3,650
Yep, I've done it. MRBF at the battery, cable to positive busbar, then a double fuse MRBF to branch off to a OB starting circuit and DC Distribution panel.
I think Blue Sea Systems makes a mounting bar specifically to mount an ANL fuse to a busbar.
May 2, 2012
276
This is what I want to mount on the BUS BAR. The lead from the battery connects to this. It is about 12" away.
1,609
Hunter 26.5 West Palm Beach
Did you test the normally high quality brands like Bussman, Gould/Shawmut, Littlefuse, etc, or only cheap brands?
