Name this Sailboat!
Oct 25, 2018
11
Miller 29 Kenmore, WA on Lake Washington
Hi everybody, I’m new to sailboats, so bare with me. I just got this sailboat for free, but I don’t know what make or model it is. I’ve reaserched for many days, and still can’t find the right answer. The previous owner sail it is a 1974 Cal 2-29, but a that’s not right.
Do any of you boat enthusiast have any ideas or clues? I would like to know.
Thanks!
Also the title should have the boat make and model on it.
“Name this Sailboat!”
Project...
Help ME?
Call me Dirty
SailAway
Money pit
Pretty Please
Diamond N’the Rough
More time
Don’t Leave
Sally
Not sure if any of these names grabs you... Naming a boat is so personal...
To narrow the search, it will be a boat designed for racing. The clue is the holes in the transom for a MOB.
The outboard looks like an add on, not the original propulsion method.
The first 3 letters in the HIN will give you the manufacturer.
Oh. You were loooking for a possible maker... First welcome to the the forum.
I like Cal boats.
This one needs work. Not your typical CAL. As the boats bow and stern are not from the typical Lapworth design. It could be an early Hunt design...https://sailboatdata.com/sailboat/cal-33-hunt
Info on the auxiliary engine, the HIN (should be on the paperwork as the boat is registered with the stat of WA, would help with manufacturer and age.
The companion way is similiar to CAL designed boats from the 70’s and 80’s.
1,929
Hunter 41 DS Port Huron
Looks like it could be a Tartan 30, if I were naming hmmmmm..... obsession maybe.
The Tartan 30 from 1970 is a possibility.
https://sailboatdata.com/sailboat/tartan-30
Windows are similar. The lines, bow and shear are similar as well as the transom.
Need more info and images. An idea of the keel and rudder shapes would help.
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
I like Cal boats.
It looks a lot like that, except to me it doesn't have as much beam as the spec shows.
The outboard setup is embarrassing. Just my opinion
1,287
Whatever it is, that "free" boat is going to cost you some $$......
Jan 13, 2009
394
J Boat 92 78 Sandusky
No way is it a Tartan 30. Transom wrong. Also not a Cal 29, 30, 33-1. Lapworth did a different transom. Ericson 32-2 with outboard stuck on the back?
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
It's a tiller boat. Even the 30-ft C&C's are wheeled, it looks as if. So probably not one of those either.
Oct 25, 2018
11
The boat does not have identification, which is why I’m having a hard time finding the make and model. However, the racing suggestion made the best possibilities come up when searching. It might be a Peterson something.... but not quite...idk.
Any more ideas?
Jul 27, 2011
5,203
Typical--I'm new. I know nothing about sailboats, but I know there is no HIN number even if I have no idea what one is or where to look for it, and even though it has a WN registration number plainly obvious in the photo that I might pursue, I'm convinced there is no identification possible:doh:.
If the previous owner didn't know the actual make it model, he could have made it up just to get our registered. How long is her overall length, really?
-Will ( Dragonfly)
Jul 27, 2011
5,203
The HIN number would be with the registration information, unless that was made up as well.
