Restoring faded colored gelcoat; best fast option
Jan 24, 2017
670
Hunter 34 Toms River Nj
Don't used poly glow !!!
It is almost impossible to remove.
Just spent three days stripping it off my friends boat.
Used mineral spirits, acetone, pressure washer.
Nothing removed it. Only thing that seamed to work was floor stripper and rubbing compound. Poly glow looked good for the first season then started to yellow.
Jun 14, 2010
2,289
One thing I learned from Maine Sail's buff wax article is that you need to use progressively finer abrasion to get good shine. Wet sand off oxidized, then compound, then finer compound, then maybe polish with foam pad. This is because any scratches left in the gelcoat will catch and scatter UV, causing quicker breakdown of the shine. Although the boat might look shiny after compound, it still needs at least another polish with finer compound like the Presta Ultra Cutting Creme or 3M Finesse-it, to take out those fine scratches left by the compound.
I had followed Mainsail's process EXACTLY. Same products, including wash and pads. You're wrong to assume that all gelcoat is the same. The shine doesn't last if the gelcoat is old and porous.
One year I wet sanded a test area before going through the full annual compounding process, and it didn't make a difference in longevity.... Still turning chalky by August. Paint was the best solution for my boat. It was expensive, but it's been 4 years and the paint still looks nearly new (with minimal work).
I have ~240 feet of topsides (3x40 ft. hulls) Instead of 5 days of compounding and waxing, I spend about 5 hours total, washing with Imar soap followed by a coat of Awlcare (simply wipe on wipe off).
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
That's because Polyglow/New Glass 2 are acrylic based. Straight ammonia probably would have taken it off.
I remember the dingy kitchen floor of a rented apartment years and years ago. I thought it had a "walnut" fake floor. I spent a whole weekend scrubbing it with straight ammonia to discover that it really had fake oak parquet flooring. That's how dark it looked after years of grime and grease and layers of no-wax floor shine. Sealed it up with acrylic floor "wax," which was probably Future brand at the time.
Aug 3, 2012
2,542
Yes. I have removed acrylic before. A friend applied acrylic to my cockpit and deck without wiping it down first. He trapped dirt in the acrylic! Ugh. I wiped it down with the polish remover the next day, and it was fine.
Nov 8, 2010
11,386
Update: I ended up going with Shurhold BuffMagic and the their wax. While a mixup with a crew member having the wrong polisher (not a DA VS unit) might have cost us some, we are very happy with results, both in the deepening of the color, and the shine. This kinda captures it.
On the water
Pat
Jun 7, 2004
1,250
We've never been successful getting the poly glow off our 272 LE...big mistake...the only product that has worked at all is commercial floor wax stripper....using poly glow was our biggest mistake. Your Beneteau looks great !!!!.. Patrick
Apr 4, 2016
201
Newport 28 Richardson Marina
Glad you went with the buff magic option too. I think she looks great, an old boat is not supposed to shine like a new Mercedes in my opinion.
Jun 14, 2010
2,289
On the water
Nice color. Now let's see if it lasts.
Gunni
Mar 16, 2010
5,937
That looks pretty good! You get another shot at it next spring. In fact working up the shine over several spring commissionings will show improving results, and get progressively easier.
Jul 7, 2004
8,481
Hunter 30T Cheney, KS
I agree. After following Main's recipe last year, this Spring prep was a breeze!
pateco
Aug 12, 2014
2,207
How did you like the Buff Magic? I am considering for my next haul out.
Gunni
Mar 16, 2010
5,937
This year I didn't even break out the Presta Gelcoat Compound, just the Cutting Creme which is much easier to work. Next year I will likely just buff some Ultra Polish and finish with Collinite insulator wax - man that stuff goes on easy and sinks in.
Nov 8, 2010
11,386
For sure. Next year the pre-launch list will be WAY shorter than this year, and we'll hit it again.
Nov 8, 2010
11,386
Its pretty awesome stuff. BlueJ probably had not been done for 10 years (I'm not kidding) except for some wipe on/wipe off stuff. Its really straightened her out.
Jul 7, 2004
8,481
Likewise. Just the cutting creme and 2 coats of Collinite. Particularly focusing on the waterline
Likes: Gunni
Nov 9, 2012
2,500
After my first full on buff with Maine Sail's instructions, I have been able to use the Cutting Creme to get the bit of oxidation off. This year I didn't have enough, but I did have a full bottle of 3M Finesse-It, which has done a very good job.
I saw a "how to" for Jamestown Distributor's Total Boat brand polish, where they painted the polish right on the hull with a chip brush, then hit it with the polisher. Since the Finesse-It is more like thin mayonnaise consistency, I tried that, rather than before of having to put the Cutting Creme on the polisher. I think the Finessse-It did a great job with painting it on. I think the Total Boat product is runnier like the Finesse-It.
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
Capt Don swears by Poli-Glow
We use PolyGlow as well. It goes on VERY easy - you just wipe it on with the chamois-covered applicator. After the second coat it is hard to tell where is the wet part you just wiped on ends and the dry coat begins. The essential part is having the surface clean. As they say, PolyGlow will make dirt shiny! Our dark green Awlgrip looks very dull and cloudy, but is dark and shiny with the first coat of PolyGlow. I haven't waxed or buffed for the past 8 years since starting to use PolyGlow.
Dec 29, 2008
806
Then I apply with a sponge that is just damp
This is where the PolyGlow applicator works well. Even if you don't use their product, I'd get their applicator. With it, even the first coat has no streaks.
