Sander / Paint removal gut check...
Aug 3, 2012
2,542
As for lifting a 19 ft boat, build a cradle for the stern. Lower the trailer tongue to the ground to raise the stern high as you can. Slide the cradle under the stern as far as you can. Raise the tongue on the trailer jack, and the boat will lift right off the trailer, suspended between the bow roller and the cradle.
You can make the cradle from a sheet of plywood cut to the form of the stern and built into a stand. Lots of ways to do it.
Before I had a cradle, I used an engine hoist / crane at the stern with a towing strap looped forward around the keel (C22 swing keel). Raise the hoist and lift the hull off the trailer from the stern with the bow resting on the roller.
You could use a floor jack with some blocks of wood too. In that case, raise the tongue as high as you can to lower the stern to the floor jack. Brace the stern with blocks of wood, raise the jack to lift the boat off the trailer, suspending it between bow roller and floor jack.
You could use the hoist on a boat up to 22 ft with shoal draft. You could use a cradle on a larger boat, but again with shoal draft.
Also, if you are gonna trailer sail this boat, you don't need bottom paint.
Aug 31, 2015
43
Oday 19 Mystic, ct
Thanks again. I think I can pull off a cradle. I was thinking I needed to get the trailer out from under it.
I am confused on the advice for painting however. I get that trailer sailing doesn't require ablative paint or if new any paint at all however mine has several layers of old paint that is chipping off everywhere so I thought I needed to get all that off.
I also found fiberglass when I was sanding so I assume I need that covered up with either gelcoat paste or a barrier coat.
And after all that I would need regular paint to smooth it all out. Cover up my sanding and/or the barrier coat.
Am I off with that understanding?
I also have aspirations to race a bit. I know it is not a real race boat but I would race a shopping cart and coming in last doesn't bother me.
Again thanks for all the help!
Sep 8, 2014
2,551
I don't get what you are talking about wit the trailer? Does it need to be painted? Maybe... but worry about the boat first.
You should only be sanding below the waterline (boot stripe). If you sanded above that line, you shot yourself in the foot.
BELOW the waterline, when you are done sanding, you only need TWO paints;
1. Interlux Interprotect 2000. This is an epoxy barrier coat, it seals everything and is also the primer for the bottom paint.
2. Bottom Paint. Your antifoul paint, ablative is only one type of several you can use. If your boat stays in the water for more than weekend at a time, anti-foul paint is a good idea. If you are a trailer sailor every time, meaning you ALWAYS haul the boat out on the trailer after only a day or no more than three in the water, you DO NOT need an antifoul paint! You can use regular glossy 'topsides' paint which will be slick and make you faster. You need to do your research on antifoul paint if you decide to use it. If you decide you still need anti-foul paint, but you will still haul the boat on the trailer sometimes, you need to know that some types of anti-foul paint will break down in open air and become ineffective. Some anti-foul paints are 'soft', they rub off easily so are not suitable for trailerable boats. I picked an anti-foul paint that does not break down in oxygen and is also tough enough for trailer bunks, Interlux CF (copper free). For racing, there are anti-foul paints that can be 'burnished', basically take a steel putty knife and rub over the surface (hard) of the dried paint... it gives it a somewhat glossy and slick surface. This job is a royal pain in the butt and has to be repeated since the antifoul paint sloughs off and looses its slickness after a few races.
That's all you need below the boot stripe.... If you sanded above that line, then you'll have to paint that too. There are numerous paints and primers you can use but that's a whole different beast. Get the bottom done and get her back on the trailer, then you can work on other stuff later.
BTW, if your trailer needs to be painted, take it to a professional and have it sand blasted and sprayed with an epoxy primer. trust me, the work and time involved in cleaning up and painting a trailer isn't worth it. JMO
43
Oday 19 Mystic, ct
Oh no. Not talking about the trailer at all.
I was referred to advice to not do bottom paint at all because I will be trailer sailing. Hauling out every time. (Maybe an overnight or two).
So what I am doing is right? Sanding down to the gelcoat. Then applying a barrier coat. Then a finishing coat. I was not going with ablative just "regular".
Above the boots tripe is ugly and the paint is also coming off. The first owner put some stripes on it. I think that may be next year project.
Do I have it right?
I did also want to check the dagger board. It's not lowered on a winch just rope (line?) but I have no idea when the pivot bolts were replaced if ever.
I am all outside on this so no cool boat swings for me.
Thanks!
Jun 2, 2004
1,957
Oday Day Sailer Wareham, MA
Unless she has been modified, your boat does not have a dagger board. However, she does have a CENTERBOARD and there is no "pivot bolt" per se, the O'DAY 19 has the same setup as other O'DAY centerboard and Keel/Centerboard boats at the time had, the CB pivots on a hard plastic (Nylon?) pin, about 3/4"-7/8" In diameter, and the pin is held into the boat by a pair of fiberglass wedges inserted from under the boat and held in by 2 stainless-steel plates, one on each side of the centerboard slot. The pate are held on by 2 stainless-steel screws each, there may also be a third screw In each plate that screws into the wedge. The pivot pins are pretty durable, but if it is worn, a new one can be purchased from D&R Marine (www.drmarine.com ). I'll include a drawing of the basic assembly below (it is labeled DSII, but 19 is basically the same, and I actually got the drawing from a 222 owner) and a few pics of the O'DAY 19 CB slot with the centerboard removed.
Minor Terminology: Daggerboard usually housed In a vertical trunk and is moved vertical up and down like a knife In a sheath to adjust depth. Centerboard is the general term for an fin that can be raised/lowered allowing variation in depth, also changes balance of center of resistance to leeway In relation to center of sail area. A Centerboard, often called a "swing centerboard" if it pivots fore and aft as it is raised/lowered, usually retracts like a jackknife being closed/opened. Usually a Centerboard pivots up and down, a daggerboard slides up and down and can often be completely removed right out the top of it's trunk.
Now to REALLY confuse you! A daggerboard is technically a type of centerboard (that retracts vertically in the trunk), the old every square is a rectangle, but a rectangle isn't always a square. Tomato vs Tomaato.....
43
Oday 19 Mystic, ct
Knowledge! - I have always wondered what I had - I thought a swing keel had to be weighted and then I saw "something" board and could only remember dagger. Makes sense.
So my pivot thing (nautical term) should be ok. Is it one of those things where if there is play in it then I should look further?
Well my update is that I hadn't touched the sanding. I have been on the road. I am going to start on the cradle next. So to measure it correctly I drop the front of the trailer and then measure from the ground up to the bottom so I can slide it under?
I think I have a decent plan. Time is now my problem. I wanted to drop it in July 2nd......
Thanks all!
Aug 3, 2012
2,542
For the cradle:
Drop the tongue of your trailer as low as possible.
Climb forward from under the stern of your boat a few feet.
Measure from the ground up to the center of the bottom
Measure from the ground up off the center about 2 ft.
Make a cradle that fits those measurements.
Slide it forward under the stern til it contacts the bottom. Put some carpet to protect the bottom and blocks to shim any gaps.
Raise the trailer tongue til the boat is suspended between the bow roller of the trailer and the cradle far enough off the trailer to do your work.
Here is a photo:
Aug 31, 2015
43
Oday 19 Mystic, ct
Great instructions. Thanks for the help. Now I know what to do with the leftover wood from my old deck!
Going to get started tonight.
Much appreciated.
Aug 1, 2011
3,972
If you're going to apply barrier coat, you must remove all the old paint. What that statement doesn't say, is that if you use an 80 grit in an orbital sander, you can get down to gelcoat and the "old blue" will still be there, as the dust will get into the sanded areas and appear to still be on the hull, when in fact it's just dust. Most gelcoat is not inches thick, so attempting to get the gel really clean with the sander is a recipe for disaster most likely.
You might consider one coat of barrier when the old paint is off, and if the boat is strictly trailer sailed, don't even bother with ablative because the boat won't be in the water, unused, for extended periods of time.
Likes: agprice22
Aug 31, 2015
43
Oday 19 Mystic, ct
Man this is a pain in the butt!!
I spent a couple hours yesterday and barely got much done.. I used 40 grit and it seemed to work a little better than 60 but left the gel coat very rough.
I will have to resand with 180 before the barrier coat I think.
Or...... Get a quote. At this rate I will never get on the water!
3,972
Yep. 40 is quite probably too aggressive. I used 60 this spring, and got about 2-3 sq ft per disk, went through 3 100-packs, 2 sanders and I didn't keep track of how many cartridges for the respirator.
It looked like this, more or less for 4 weeks.
Ward H
Nov 7, 2011
3,843
Having the yard media blast the bottom instead of me scrapping or sanding was one of the best spends I made. If I had to sand or scrap the bottom I never would have gotten in the water the first year.
Aug 31, 2015
43
Oday 19 Mystic, ct
So I got a quote from a yard.
3350 for blasting, barrier coat and painting.
I bought the boat for 1400 so it is out of my budget.
I did buy a sanding disk that drops in a drill. Much better than a random orbital. Hopefully quicker.
Back to Sanding........
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
QUOTE]
You may not like the results of the circular action. Be careful. And lighten up on the grit. You probably shouldn't be more aggressive than 80.
Aug 1, 2011
3,972
This won't end well. It's not a job that can be "hurried up", it's dirty, messy and takes time. attacking it with harsher tools will lead you to a big patch of gelcoat removed from the bottom that will be an order of magnitude harder to repair. All you want to do is remove the old paint. The gelcoat may not be much thicker than the old paint, and once removed, the fiberglass is exposed.
Your boat, your choice. There are many people here who have done this job, and nobody ever came on here saying what fun it was.
Aug 31, 2015
43
Oday 19 Mystic, ct
So this thing is a bad idea because it won't be even and I may gouge?
Back to the random orbital?
2,542
I do not think you will like the results of using the disk sander. It will be more tiring, and it will wobble and make divots. Also, the speed will be harder to control.
I think you will be happier with the orbital palm sander. You can use 40 grit. I used it on my boat. It had years of old paint, but I got through it. It is tiring, pressing upwards beneath the boat. Just press lightly, and use the vacuum attachment. Keep your eye on the bottom. When you see white, you are done.
Also, you do not have to smooth it out with 180 later. If you put Interlux 2000 barrier protectant on the bottom, it will come out great. Mine did!
Aug 31, 2015
43
Oday 19 Mystic, ct
Quick update.
I had a breakthrough. I spent three -four hours and you can see the very slow progress in the starboard pic. I did this with just a palm sander and 40-60 grit paper and a vacuum. Frustrated i sat there picking off the paint with my finger and thought for S&Gs let me get a straight blade scraper. Well holy S&#T. The paint came flying off!! The port side pic I scrapped and sanded in under 5 minutes!!
The blades don't last long but they are really cheap so who cares. I have now more than half the boat scraped and did it in 30-40 mi Utes. Then just clean up with sanding. I can use 80-100 grit and get to the gelcoat really quick.
This probabaly saved me 10 hours of just sanding and the clean up is really easy and barely any dust.
Whoooo hoooo!
3,972
It will. The ip2000 wants an 80 grit finish. I found that to maybe be too aggressive, and offer that as what I saw. I would not deviate too far from the recommendations, as you've unquestionably experienced, this isn't a job you want to do very often.
Also, take the paint to a store and if it costs you $10 to get it shaken, it IS money well spent. The stuff is like runny peanut butter when mixed properly, and you cannot do it by hand.
