I can tell you from multiple experiences that once you pull a halyard knot tight, the only way to get it off is to cut it. The only way. It will NEVER come loose. . That role is what it's designed to do. That's why they call it the halyard knot.it looks like to me that the halyard hitch would be easier to get loose as in removing it
Wrong Ron, never. Maybe you're talking about a different thing. Never use a bowline to tie a halyard to a shackle.The bowline has a long-known and documented history of loosening when shaken off-tension. I would never personally trust a bowline in a place where I could not see the knot.MM,
I simply use a Bowline pal.
Yea, it's a bit bigger & my not fit as well on different model boats but, if tied correctly will NEVER fail you.
That is a nifty little knot! I keep a small bit of line in my cubicle at work, and I learned this one today, thanks for the link!Howdy MM, Halyard hitch is one of the animated instructionals on this website:
http://www.animatedknots.com/halyar...png&Website=www.animatedknots.com#ScrollPoint
Using the knot I mentioned above, without a shackle, lets you raise the sail to it's maximum height. Plus it can be "tied" in less time than it takes to unscrew a shackle pin (especially after it gets dropped)I started using the halyard hitch when I was looking for a compact knot. Slight drift but what are the pros and cons of tying the halyard to a shackle vs directly to the headboard of the main sail?
That knot is used on dinghies and small (<20) foot boats that tie their sails to halyards. On bigger boat that are designed to use shackles, the rig is designed with extra space on the spar to allow the designed/speced sail to be pulled to full hoist.Using the knot I mentioned above, without a shackle, lets you raise the sail to it's maximum height. Plus it can be "tied" in less time than it takes to unscrew a shackle pin (especially after it gets dropped)
My first three boats were dinghies, so I guess that explains it. Still works for me on the M25 however.That knot is used on dinghies and small (<20) foot boats that tie their sails to halyards. On bigger boat that are designed to use shackles, the rig is designed with extra space on the spar to allow the designed/speced sail to be pulled to full hoist.
Yea, exactly why experts (not just me) recommend not using for any situation where the knot can come off load. Any given individual of course might not have experienced it, but it pays to look at collective experience.had a bowline shake Loose when loaded suddenly...lost my bucket in Lake Michigan trying to scoop up some deck rinse water. some books will suggest a half hitch on the tail end to help.
