Hi Phil, thanks for posting, it has been a lot of fun to watch you fix-up your Catalina 27. I was hoping to get a Catalina 27 project in the future and go cruising around the world. I need to build a trailer first, so I can pick up one of the deals I keep seeing. I can't find much info on building a sailboat trailer less some online pictures and some cradle specs from Catalina. I was hoping you could measure what main size C-channel they used on your trailer and where the boat is centered over the axles and if the tongue weight seemed about right when you were hauling it. I should be able to figure out the rest, and there is no rush, I am just kind of planning and gathering info right now. The easy part.
Williams, Mt. Pleasant, TX
